Home > Modifications & Maintenance (L663) > CB Radio / Firewall passthrough FYI
dontwakemeup
Australia
For anyone else wondering:
My experience is with a RHD vehicle.
There is a perfect passthrough for an antenna on the passenger firewall under the fusebox. Very large grommet with harness in it, and then directly above that is a nipple.
Could also be used for other things but it was so easy I was amazed. You need to cut the end off the nipple and feed your wire through.
I fitted my CB radio in the main console (i have a jumpseat) and wired it off the cig lighter. Used a Cat 6 passthrough so it's removable when not in use and has a dustcap. That interior part (which I drilled through) from the dealer to replace (in case i sell the car) is cheap like 70 dollars.
Post #894249 27th Mar 2021 7:05am
