Home > Maintenance & Modifications > Sub-Frame and Slide Assembly - type of bolts please
rustyredwreck
England 2003 Defender 90 Td5 SW Baltic Blue
Dear all,
I am in the process of separating the seat sliding mechanism from the seat sub-frame - essentially part MXC5778 separates into 2 parts. The lower part (the seat sliding mechanism) will be fitted onto 2 new front seats I have.
The 2 halves of the frame are held together by 6 bolts (3 either side per seat) - see picture below.
The parts manual only shows the seat sub-frame as a single element - so I cannot identify the bolts part number.
The bolt has a thread length of approximately 31mm and a diameter of approximately 7mm and, from previous posts on this forum, appears to be a pozidrive bolt.
Is anyone able to confirm what specification bolt I should be looking for?
Kind Regards
Neil
Post #894088 26th Mar 2021 10:44am
rallysteve
Looks very much like an ISO 7047 type head to me and would assume it is M8 but if the O/D is only 7mm then might be 1/4 UNC (thread pitch looks more like M8 1.25 to me though from the photo).
Can get stainless M8 with this head type from Westfield:
https://www.westfieldfasteners.co.uk/A2_Sc...sk_M8.html
Post #894100 26th Mar 2021 11:33am
rustyredwreck
Hello Steve,
Thanks for taking the trouble to respond.
I'll go ahead and place an order with Westfield.
Kind Regards
Neil
Post #894107 26th Mar 2021 12:00pm
