Home > Wheels & Tyres > Wheel rim choice.
Page 3 of 4 <1234>
L110CDL
I have been looking at allot of wheels and if my modulars are ET 0 the blindos are ET 15, will that be okay to fit under the arches with a load on or articulation on the angles ? Clayton.
Keeper.
Post #895194 31st Mar 2021 8:52pm
Dinnu
ET 0 means that if you view from the front (or back) the centerline at tyre width will line up with the hub face.
ET greater than 0 (positive), the centre of the tyre width will move inwards relative to the hub face.
So with ET15, assuming you have the same tyre, you should get 15mm more clearance (horizontal distance) from the wheel arch compared to ET0.
The inner arch / the tub.. I think there is quite some clearance there.
The vertical clearance between tyre and tub, that is mostly affected by tyre size... but can always fit thicker bump stops if the spring is being compressed fully when loaded and articulated. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #895198 31st Mar 2021 9:12pm
L110CDL
I understood all of that information, many thanks Dinnu Thumbs Up Clayton.
Keeper.
Post #895199 31st Mar 2021 9:18pm
Dinnu
Sorry, I think it was obvious information.
Real life experience,, on a 90 however, with softer springs such that on full articulation, the wheels with load get compressed almost touching the standard bump stops. +2 shock absorbers, so the wheel with no load droops 2 inches more (effectively making the wheel on the opposite side (with load) to get closer to the tub / wheel arch. Standard boost alloys (ET33) but with 30mm spacers, so that would become same as an ET3. 285/75 tyres, and they just scrape the wheel arch at full articulation. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #895204 31st Mar 2021 9:34pm
L110CDL
Thumbs Up Clayton.
Keeper.
Post #895212 31st Mar 2021 9:45pm
L110CDL
So with me chopping and changing from day to day on what wheel rims to choose Rolling Eyes with Blindos can i re- use the alloy nuts i had with the set in the second pic i posted or do blindos have to have special nuts Question
many thanks Smile Clayton.
Keeper.
Post #895432 1st Apr 2021 8:08pm
Blondos are your normal genuine LR alloy nuts.
Post #895435 1st Apr 2021 8:18pm
L110CDL
Great, many thanks GREENI Thumbs Up Clayton.
Keeper.
Post #895438 1st Apr 2021 8:22pm
Blondos Laughing you can tell i don’t have my glasses on.
Post #895455 1st Apr 2021 9:11pm
L110CDL
Iv'e got mine on and still i didn't see the mistake Laughing Clayton.
Keeper.
Post #895459 1st Apr 2021 9:44pm
L110CDL
So to bring this thread to a ending, i went for these
Well chuffed with them Mr. Green Clayton.
Keeper.
Post #901387 4th May 2021 9:18pm
DAZ110
Oooh, ...very posh. Wink Thumbs Up
Post #901392 4th May 2021 9:32pm
jimbo55
Looking good Clayton, really suits the look of your truck 👍
Post #901393 4th May 2021 9:32pm
L110CDL
Thank you DAZ and jimbo Thumbs Up Clayton.
Keeper.
Post #901415 4th May 2021 10:28pm
Good choice! Thumbs Up
Post #901416 4th May 2021 10:34pm
Page 3 of 4 <1234>
