Home > Modifications & Maintenance (L663) > Patriot Rack for New Defender |
Whilst I've no doubt that would be possible, it'd just be too complicated to be useful. You'd end up with a graph tells you that you mustn't go around corners faster than xx mph or on side slopes greater than y degrees on a sliding scale of weight carried, which is fraught with difficulties to assess. Far better from the manufacturers point of view to just state a limit in the way that they have. Darren
21st Mar 2021 8:51am |
Or some just apply their own risk assessment :
Click image to enlarge |
21st Mar 2021 4:04pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
More likely to give clearance for GPS signals as the sharks fin is also the GPS antenna and the antenna would be shielded by a closely mounted steel roof rack and any load on it Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
31st Oct 2021 10:04am |
