![]() | Home > INEOS Grenadier > Alpine Lashing Points |
Well apparently they may be removable and the bar can be replaced with clamps, studs or lugs:
![]() Click image to enlarge ![]() Click image to enlarge And it can also be used as extra storage: ![]() Click image to enlarge "the recessed roof panel 300 of Figure 4 may have a substantially empty cavity defined by the concave surface of the basin. This cavity may be used as an additional 25 storage compartment of the vehicle. In the example of Figure 4, a cover 310 may be provided that closes the cavity defined for protecting the cavity of the basin from the outside environment, e.g. rain or dust. The cover 310 may be pivotably connected to the housing, e.g. to the lip portion 304 of the housing, via one or more hinges 306,308. In order to help operators open and close the cover 310, an optional handle 312 may be provided on the cover 310." ![]() Click image to enlarge https://www.ipo.gov.uk/p-ipsum/Case/ApplicationNumber/GB2008700.3 |
