![]() | Home > General & Technical (L663) > Auto Roof Blind |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 177 ![]() ![]() |
Mine does that if you close it via the switch, just start the car then open it with the switch, it then works on unlocking and locking again.
Philip Member Since: 09 Mar 2018 Location: England Posts: 510 ![]() ![]() |
If it’s like the Range Rover, adjusting it when it’s set to auto overrides it - try closing it before you turn off, then toggle it off and on again.
39Steps Member Since: 12 Dec 2020 Location: UK Posts: 48 ![]() |
Great thank you both for the replies, sounds simple enough!
Scrumps Member Since: 24 Feb 2021 Location: Somerset Posts: 108 ![]() ![]() ![]() |
Hi,
Try this:- https://www.ownerinfo.landrover.com/docume...c/G1972384 Or look under “maintenance” in the iGuide Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Something else to watch out for: SOMETIMES my sunroof won’t fully close it shuts the pops back up to the tilted position. The cause is also the blind, it can get slightly out of synch with the glass panel. I’ve found that opening the blind fully then closing the glass by pressing the button fixes the issue and next time I open the car the blind has closed itself and re-opens automatically when I start the engine. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Tim,
There is a pano roof reset in the same section of the iGuide too which re-sync the blind ( if I’m reading it correctly). Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Thanks again for the replies. OK so far have tried the suggestions, with the exception of the roof reset, and Tim's suggestion as I have only just read them! So far it is not sorted. Unless I am being a total numpty, on the roof blind reset, I am presuming it is the close button that has to be pressed for 30 seconds, otherwise the blind opens using the opening button, but I get no click and therefore the next part doesn't happen.
Will try the reset of both the roof (and the blind) again and hope for a more positive outcome. Thanks again. I will report back! |
Q86ARR Member Since: 28 Feb 2017 Location: Earth Posts: 38 ![]() |
Is the blind open when you lock the car?
It will only open on unlocking if it was open when it was locked |
Thanks for the reply. No it isn't however it never was, when we collected the car, the blind would automatically open upon unlocking and close on locking. It doesn't now irrespective of auto blind being switched on in the climate settings.
dontwakemeup Member Since: 28 Feb 2021 Location: Oz Posts: 55 ![]() ![]() |
There are different calibration steps depending on your VIN:
I have attached them here: The following step(s) applies to: Vehicles built up to VIN:SALEP7EUXL2019064 Use the Jaguar Land Rover (JLR) approved diagnostic equipment to calibrate the roof opening panel blind/roof opening panel glass. General Equipment: Jaguar Land Rover approved diagnostic equipment The following step(s) applies to: Vehicles built from VIN:SALEP7EUXL2019064 Initialize the roof opening panel blind/roof opening panel glass as follows: Start the engine and leave running during the initialization process Make sure that the roof opening panel blind/roof opening panel glass is in the fully closed position - press the close switch to achieve this Press and hold the close switch again and wait for the roof opening panel glass to jog forward a few millimetres and then return to its original position (this should take approximately 30 seconds), then release the switch Within 3 seconds, press and hold the close switch. The roof opening panel blind/roof opening panel glass will automatically travel toward the open position and then to the fully closed position. Release the switch when movement is complete |
Thank you. That sounds similar to the reset function I tried earlier, but I will try again in the morning and report back. I appreciate your help.
Update as promised. All sorted. The reset does not happen on the roof blind button. When I reset the panoramic roof itself it resets the roof and the blind.
The last position the blind is left in when locking the car is the position it will revert to when opened. So it seemed to be a combination of everyone's replies, so many thanks to everyone! |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
Is there an option like on the disco that turns off the auto roof blind, I’m sure it’s a convenience feature option, but it might not be on the defender I’ve not looked Mike
Yes there is an option to disable the auto open for the roller blind - after running the engine manually close the blind BEFORE switching off the engine, next time you start the engine the blind will not open. To reset it to auto open again next time you run the engine open the blind before switching off and it will then auto open the next time you restart the engine.
Caveat: this works on my 2020 First Edition, don’t know about 2121 or 2022 MY cars. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
