![]() | Home > Modifications & Maintenance (L663) > Has anyone fitted roof rails after? |
SN Member Since: 29 Jun 2007 Location: SK6 Posts: 729 ![]() |
simon at powerfuluk has - note you're going to need a 5 point-star-with-centre-pin driver head to get the original trim off - simon does call them out.
footnote: I shall be checking how neatly my dealership has done mine when it turns up ![]() To be fair doesn't look any harder than the roof rails I put on my first Disco 3 about 15 years ago - I actually found the trims I took off in the garage roof space at the weekend! ![]() ![]() ![]() ![]() |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
I had them fitted 2 months after taking delivery of the car but got the dealer to do it while the car was in for warranty work, I had the rear recovery eyes fitted at the same time. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
Thanks for the link.
Already have the Torx Plus bits so I'm sorted on that front. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
GSKM Member Since: 22 Aug 2020 Location: Shropshire Posts: 5 ![]() ![]() |
WRT the 5 point-star-with-centre-pin driver head fitting, some idiot cut the cable of my hedge cutter whilst I... er they were using it. I took all but one torx bit out with a normal torx driver. The last one was a safety torx bit, with the centre pin. I did not have the tool to remove it. However an electrical screwdriver rammed between the points and the pin worked well to remove it. I wouldn’t advise using that method to remove roof bolts though. Hmm, the thought of the screwdriver slipping on the roof doesn’t bear thinking about. 1983 110 2286 petrol hardtop.
2015my Freelander 2018my Discovery Sport. |
