Home > Wheels & Tyres > 285/75R16
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
285/75R16
Can anybody who runs 285/75R16s measure across the tread contact patch for me please, i.e. the width of the footprint it would leave on the ground?
Particularly interested in BFG MT KM2 / KM3 and the Cooper Discoverer STT Pro to compare the widths.
I am thinking about getting 285s for the Puma on some alloys, and I recall some of the older BFG sizes having quite a narrow footprint for the section width, but I don't have any available to measure.
Thanks Thumbs Up ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #890683 11th Mar 2021 10:07am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Wouldn't that be 285mm, regardless of which tyre?
I thought that it was 285 = width in mm, 75 would be % of width as sidewall height - i.e. 213mm in your case of a 75 profile, on a 16" rim?
A 110 Tdci Double Cab
Post #890700 11th Mar 2021 10:35am
jimbo55
Ay4alex, it should be that simple but unfortunately it’s not, all manufacturers and tread patterns are quite different
The picture below shows a 255 BFG mud compared to a 265 BFG AT, but there’s a 2 and a bit inch difference in width and not just the 10mm difference on paper
Post #890723 11th Mar 2021 11:51am
I think the problem here is that the number we all think of as tread width (255, 285, etc.) is actually the section width, which is a different measurement:
The actual tread width can vary between manufacturers and tread patterns. Darren
Post #890726 11th Mar 2021 12:07pm
hank
As per LRA above, tread width, sectional width and overall width are different.
Below is my BFG MT 285 75 16 KM2. It's the 'side knobbles' that give the overall width of 285
 > 110 XS Double Cab
Post #890729 11th Mar 2021 12:20pm
ay4alex
You learn something every day! Thumbs Up 110 Tdci Double Cab
Post #890730 11th Mar 2021 12:29pm
jst
Will also depend on the rim width its fitted to. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #890840 11th Mar 2021 9:10pm
Mdm
235 85 16 km 2 versus km3.
km 2 is on a7 inch steel modular rim ad km 3 on a boost alloy also 7" wide rim
Post #890869 12th Mar 2021 6:23am
BogMonster
A
No, hence the question. The footprint of tyres relative to their section width varies considerably. I used to run BFG 265/75R16 when they made the original MT KM, the reason I didn't move to the KM2s was that the footprint was about an inch narrower for the same section width! That will suit some terrain like the UK, but not here. Soft peat is quite commonly 5-10 metres deep (or more) so a tyre that will dig down to the hard ground is ... not that effective Laughing
Hank, thanks for the pics, just what I needed for one type. Anybody got a similar image for a 285 KM3 or Cooper? ---
Post #890888 12th Mar 2021 8:51am
BogMonster
Is anybody able to get a tread/tape measure photo for a KM3 or Cooper similar to the ones above please? ---
Post #892264 18th Mar 2021 8:48am
camelman
I'm running 315/70/16 KM3s.
Just measured up and the actual main tread blocks side to side (i.e. the bit on tarmax) is only 260mm.
As mentioned above, the 315 is the full width of the tyre.
Post #892266 18th Mar 2021 8:56am
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
285/75 Cooper st Maxx
I know it’s not exactly what you asked for but I’m bored at work, so took it anyway😉😉
245 tread width 2002 td5 90 county hardtop
Post #892288 18th Mar 2021 9:44am
jaygti
That’s on an 8 inch rim. 2002 td5 90 county hardtop
Post #892290 18th Mar 2021 9:46am
jimbo55
Finally went and measured the 255’s on my defender, fitted on 8.5” rims
Overall width was 275mm
Tread width was 190mm
Post #893482 23rd Mar 2021 5:02pm
