Home > My Defender > Def 110, 2012 Blaser Edition in Norway |
Black Puma Member Since: 31 Jan 2015 Location: Sydney Posts: 203 |
Great intro Jacek. Great Defender too.
Really enjoyed your story and, the photos. If it makes you feel a little better, my clutch had to be replaced at my own expense, just 3 days past the warranty. It was the most expensive thing I had to do on the truck so far. Theses things happen. Sounds like you had a lot of major issues fixed, so now you can enjoy |
10th Mar 2021 10:39pm |
BrunoJ Member Since: 14 Sep 2019 Location: Stavanger Posts: 75 |
Thanks.
And sorry for the clutch, that's a bad luck really. In my case I did expect it, but hoped it will die slowly and I'll manage to explore it till last millimeter. Unfortunately gearbox doesn't support well slow driving in the city. Doesn't really make sense to change into low gears (although I'm using it sometimes), while regular gears, especially 2nd, requires quite often using the half-clutch to avoid 'shaking'. It most probably kills the clutch faster, unfortunately. |
10th Mar 2021 11:14pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Very interesting story Jacek. That’s a lovely 110 you have there. Please let us know how your camping modifications project progresses
11th Mar 2021 7:18am |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 |
Interested thread BrunoJ & quite a unique camper, thanks for sharing.
I used to travel to Norway with my work & never saw many Defender's but absolutely loved the country & the Norwegians...welcome to the forum. Still have Akevitt flashbacks!!!! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
11th Mar 2021 8:37am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3685 |
Very interesting. Other than the badging, what other Blaser elements are there?
11th Mar 2021 8:43am |
Thank you all.
@FatCog - Actually you can see quite a lot Defenders around. Also in the city, and definitely in villages around. There are also some really nice pieces from 50-60, well restored. Dealer keeps one of them , used during one of older J.Bond's movies. @Co1 - I saw already other owners of this version on the forum, from Switzerland if recall correctly. The additional Blaser-related element is a weapon box in the boot, also leader seats with logo. Others are rather generic LR options - aircon, electrics, roof rack, alufelgs and so on. However, there were originally fitted into this version by default. This version has also extra front lamps from Bosch and winch, which are, I believe, accessories option for German market. Not sure towbar was already there or added in Norway (which is very common here). |
11th Mar 2021 10:17am |
Thanks Bruno. I don’t recall ever seeing a Blaser edition in the UK, but their rifles have long since represented great quality so was interested to see what they carried over.
11th Mar 2021 7:00pm |
If I'm not mistaken, this version was released for Germany and Switzerland only. 60 pieces each. Announced as a hunter's edition. Potentially available in some other countries, if local dealer import them directly, like my one in Norway.
11th Mar 2021 7:14pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
Welcome to D2N What a great Defender, lovely photos.
My 110 had 3 clutches before 30k, but been fine since. Wheel spacers or et0 rims, with properly adjusted steering stop make a huge difference to turning circle. Soundproofing also helps. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
11th Mar 2021 7:35pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10817 |
Welcome and a great opening to your thread with your nice 110 Jacek 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
11th Mar 2021 9:26pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
Hi Jaeck,
welcome to the forum and lovely ro see another pop top here! there are a growing band of us now ! Not sure what make your pop top is as its not one I have seen before, but it would be good to see some inside photos some time ! For inspiration on internal fittings you can look at some of our builds as posted on here as we all have our own particular needs and preferences - but just yet if you want any help or advice Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
12th Mar 2021 8:57am |
Thanks, I'll definitely check around how others made their camper setup.
I was on the forum for a while a year ago, around the time I was buying him. The "Made" is German company called LandyCampy, which seems to do not exist any more. It looks identical like the one from Austrian Hesch, which you can check here: https://www.offroad-hesch.at/produkt-kateg...ender-110/ They, btw, offer also nice selection of camper furniture, if not to buy (rather expensive?) then at least to provide some idea how they can looks like. I like especially the setup for 5-seater, with can be converted into second sleeping level and definitely want to go into this direction. In details, especially the way how it was setup, there are small differences - I don't have ladder installed any more and I missed the water/rain protection bars (however it should be properly called) - original ones moved with the roof up, and Hesch is adding extra elements just above the doors, which I don't have. Which from time to time causes me an unexpected shower, when entering/leaving the car This is something I also want to fix, looks like kind of DYI work. I'll try to make fresh photos at nearest time with interior including tent. I should also have some photos from the work related to exchange the dashboard the radio, then I can share also some conclusions, as I'm not fully satified from final effects. |
12th Mar 2021 1:54pm |
vladanco Member Since: 29 Jul 2021 Location: Riga Posts: 2 |
Good morning,
Great story! I am also the owner of Blaser Edition Defender. Just bought it few months ago. Definitely, one of the greatest purchases in my life. Really love this car...I have huge plans on upgrading it...flip-roof in my list too Is it worth it? Flip-roof. How it's in practice? Oh, and one more question. Maybe you know...is it possible, to know somehow, the exact number of Blaser Edition Defender? I mean, it says "one of 60"...but which one of those 60? Maybe there is a number somewhere? Very interesting to know |
29th Jul 2021 7:45am |
Hi, Thanks for your reply and nice to know another happy owner.
Answering (best of my knowledge) starting from the bottom. I don't think so there is any specific nr of "one of sixty". Or at least I'm not aware of. Nothing visible, but who knows, maybe it is hidden somewhere... About the pop-top roof. It is very convenient for usage, 10 seconds to open and maybe 60 to close. Enough space for 2 PAX (potentially 3 is you squeeze). Staying firm on stong wind and Norwegian rain. All depends how often it will be used and overall usage of the car. Personally I would probably prefer box tent of the roof, which I could dismount for daily usage in the city. It will allow me to use some garages at least, plus avoid some noise. From other hands, I would be probably to lasy to dismount box tent everytime, so it will stay on the roof anyway (I know few people who use it and they keep it most of the time attached to the car). So, from that perspective, it is better to have it built-in. Additional benefit - I'm using it from time to time to carry some stuff, including Ikea furniture boxes. Really nice extra space, just keep in mind to do not overload it with the weight. Some practical issues to be check with specific implementation - rain/water rails in case original roof is moving higher, how much space for heads for passengers in second row left, what about internal lighting. In short words - don't make it cheap. Consider also external marquize (awning) as it is probably worth to build it at the same time. I bought it already with pop-top roof tent, so didn't have any choise of the implementation. I believe it is worth to review various offers and you can see various solutions wich differs a lot - way how they are attached, opening and spring mechanism, but internal finishing. I recently visitied 4land.pl company in Poland, Gdynia city (information rather than recommendation, although garrage looks impressing). In their tent implementation the slepping floor is moving up some cm when tent is closed, giving more space above heads, which is one of the issue in my case. From other hands, their tent looks very bulky, some could like it, as it gives kind of "adventure" look. In my case, most of the people who are not familiar with details, they even don't recognize there is any tent overthere, it is so well integrated and I like that. There is caravan/camping section on this forum and you can see various implementation, which could give you some inspiration about tent and camper setup. I'm still not sure I want to convert my one into camper. In theory furniture are removable, but I'm sure it will not be practical and they will stay permanently in the car. Which means I'll drive with all stuff everyday, making even more noise And .. check the rust, factory protection is weak, it is worth to maintain it well from the begin, otherwise that can create the cost in the future. |
29th Jul 2021 8:29am |
