Home > Technical > Anyone know what this heat sink is?
Bundy
As title...pulled wing off for fitting a roll cage and found this disconnected behind the wing...drivers side only
What’s it for and should it be connected??
Thanks in advance
Al
Post #889359 6th Mar 2021 12:34am
donmacn
Dim/Dip - cr@p idea in the first place, and your light bulbs will thank you for leaving it disconnected.
I think there's a relay, or relay socket behind the dash somewhere that also needs/needed attention to disable this, but if the resistor is unplugged then hopefully your relay will already be sorted.
I did this on mine years ago and have forgotten all the details, but if you were to search here, or google Defender dim/dip I'm sure you'd find all the info. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #889363 6th Mar 2021 1:34am
Was a weird UK road regulation (my 200Tdi had it back in 1992) so if you were driving (or at least ignition "on") with just the sidelights switched on, the headlights would illuminate dimly
I think that resistor dropped the brighness to either 1/10th or 1/6th of normal brightness
Or just replicated a sealed beam! Rolling with laughter
Post #889376 6th Mar 2021 8:20am
It's either/or to disable the dim-dip. Either unplug the resistor as per the pictures or change/adapt the pink relay behind the instrument binnacle.
At one point, LR even offered a specially adapted relay to replace the original, which is basically a shell with just a link wire between two of the terminals inside.
The only other thing I'd add is that connector will still be live when the side lights are on, so it'd be worth taping it up properly. Darren
Post #889377 6th Mar 2021 8:32am
discomog
Diesel Jim must have had one of the last vehicles equipped with dim-dip as this stupid idea was withdrawn in 1992 at the same time as the French did away with yellow headlights - all thanks to the EU who harmonised headlamp regulations across Europe. (One of the few good ideas to come out of the EU). Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #889379 6th Mar 2021 8:36am
Retroanaconda
It might have been withdrawn but Land Rover kept fitting it right through until at least Td5 era. I have a 2006 loom with it fitted.
Post #889380 6th Mar 2021 8:44am
Despite the rule change, LR continued to fit dim dip to some Defender models for years afterwards right up to the Puma. Darren
Post #889381 6th Mar 2021 8:45am
My 2007 County-spec Puma 110 DC left the factory with dim dip, LR was still fitting the abomination to commercial-spec vehicles then. If you bought a non-commercial you got headlight level adjusters, commercial got dim dip.
I don't know when this stopped, possibly when all Defenders became N1.
It's an utterly useless feature, the most stupid idea since rear fog lights. It also kills headlight bulbs.
Post #889390 6th Mar 2021 9:29am
Bundy
Thanks everyone. Will check if it’s still live and tape it up.
Mines an 09 Puma for reference 😉
Al
Post #889391 6th Mar 2021 9:31am
markb110
Bendy, I used a spare plug set, sealed the open ends up with Dum Dum and used those to seal the now open ends.
That way you won’t have to worry about the tape ever coming off and getting water damage to the exiting loom.
Post #889476 6th Mar 2021 5:26pm
Slideywindows
Learnt something here. Thank you.
My 1996 County Hard Top still has dim-dip.
(Didn't Harry Enfield have a similar sounding character? Whistle )
Post #889495 6th Mar 2021 6:22pm
L110CDL
Yes he did Slideywindows Wink
I have just got rid of the dim-dip on Millie Very Happy Clayton.
Keeper.
Post #890038 8th Mar 2021 10:26pm
excossack
and I am trying to fix it on my Td5 110. I think its the relay. (i like the feature) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #890090 9th Mar 2021 8:44am
markb110 wrote:
... That way you won’t have to worry about the tape ever coming off and getting water damage to the exiting loom.
It's worth remembering that there are many unused connectors on a Defender and you won't get any loom damage leaving them uncapped, unless you think you might want to reuse them in the future when crud ingress could be a problem. A small plastic bag and some insulating tape, or a piece of pallet wrap, will do the job if need be.
Post #890101 9th Mar 2021 9:19am
