![]() | Home > Maintenance & Modifications > Defender 110 County < utility conversion |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3396 ![]() ![]() |
Would it not be easier to just the rear windows blacked out?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
Genuine 110 USW rear side panels are very hard to come by, as a result many people use Series 3, 2A or 2 88" hardtop sides which fit but are subtly different in construction, but are much easier to find.
You could also swap the windows out for Gullwing panels? Probably as cheap as buying new side panels
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3820 ![]() ![]() |
Does this conversion make any difference to the tax of the truck?
Station Wagon and Utility are both N1 for later vehicles anyway so wouldn't affect the road tax.
If you're trying to argue it becomes a van for company car tax purposes that's a different ballgame... ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5868 ![]() ![]() |
You can just bond a sheet of aluminium over side and loose it at the ends when painted. This also saves taking the vehicle apart. Gullwings are also an essay option but don’t give the look, and the ones I played with appeared to be far from secure
So I did it properly ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
