Home > Technical > Has anyone disassembled a set of puma 2nd row seats? |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
Long story short I need to get my 2nd row seats into the loft for storage. They are an awful lot heavier than early seats so I'm planning on stripping them down to make them more manageable and to address a couple of a defects whilst I'm at it.
Has anyone done this? I can't see any reference to it on the forum, suspect it will just be a case of removing the pivot bolt but any advice welcome. Cheers. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
1st Mar 2021 10:22am |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 |
Yep,
Pretty simple. I disassembled them to change the covers on the foam to match my front seats...and add three seat heaters for the kids. I took some pictures somewhere I think. Basic mechanical disassembly. Im not sure you will save much weight through as the steel frames were about 80% of the weight and were welded assemblies. Patrick |
4th Mar 2021 2:56am |
