Home > Technical > EGR valve removal (tuned car) TD5
FD7
2006 Defender 90 V8 Petrol ST Auto Chawton White
My car is 'stage 1' remapped already and just thinking about removing the EGR valve. Will this upset the tune or perhaps enhance it?
I seem to only be told to remove the thing....
Post #888089 27th Feb 2021 11:51am
It certainly won't upset it, and will probably result in a marginal improvement. However remember that it is strictly an offence and an MOT failure to tamper with factory fitted emissions equipment. If the tester notices, then you should fail an MOT.
Post #888097 27th Feb 2021 12:43pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Also you may not get the backing of your insurance if things go tits up Shocked
Post #888099 27th Feb 2021 12:53pm
