Home > Puma (Tdci) > What break Fluid |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
I noted the clutch master is near empty but no sign of a drip as yet.
The master seems dry (no wet foot) and the slave is a little out of sight. I suppose the leak is not enough to fill the bellhousing as yet as only 3/4 of the reservoir is empty. Now what fluid to refill with. As usual our RSA specs are not the same numbers as in the Puma book. Do you think it OK just to use a shell dot4 type? Advice apretiated Thanks James Puma 110 - gone Series III 1973 - going strong |
2nd Jan 2009 3:40pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
TRY THIS SITE. RR FLUID SPECS.MDI
GOODLUCK. |
2nd Jan 2009 5:20pm |
Found out it is the master cylinder as my wife told me she washed a sticky spot off the rubber mat a few days ago and thought it may be spilled juice as there was sand stuck to it also.
Looks like back to dealer for new master. My mates TD5 has had about 3 replaced and an unsuccessful re-sleeve in s.steel. Seems common to defender? I suppose only the slave cylinder is different due to Ford Gearbox. Puma 110 - gone Series III 1973 - going strong |
2nd Jan 2009 9:06pm |
Back to dealer then.
Good luck |
2nd Jan 2009 9:17pm |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
3rd Jan 2009 12:51pm |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
my clutch went all soft 2 days ago and i checked the level of the fluid today - it's empty.
i don't see any leaks anywhere. i've filled it up and all appears more or less normal again. this is the 3rd time this has happened (the previous 2 i took the car to the dealer - they just bled the system). what the hell is going on? how much clutch fluid should one use? the owners manual says to check the level weekly. any advice, comments? www.ralton.co.za |
27th Jul 2010 7:40am |
