![]() | Home > Td5 > 1999 TD5 CSW with Headgasket failure and cracked head |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 ![]() ![]() |
I guess it depends on the condition of the rest of the vehicle. If it were good value when I bought it, it was in otherwise fairly good condition, I'd probably mentally think I'll keep it but inform the dealer the bill was theirs to pay, knowing if they refused it wasn't the end of the world and I've then got a vehicle with a brand new rebuilt head and a checked solid engine.
If it's got other issues that that £2500 contribution you could well end up having to make yourself would really benefit from just to make it useable and you're not attached to it as "a really good one" perhaps it's a good plan to attempt to give it up as a bad job and hand it back. Difficult to know where I'd sit personally without more details on the rest of the vehicle. |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3394 ![]() ![]() |
Last td5 cylinder header we got done cost £1100 all in.
A recon head is around £500. https://www.autotechcylinderheads.com/cyli...valves=152 ![]() |
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 277 ![]() ![]() ![]() |
Perhaps a fully built up ,all new head from turner engineering for £1300 . Pay a good mechanic to fit and still quids in on original quote
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 545 ![]() ![]() |
Had 2 cracked heads ( cracked in the diesel gallery) welded up got about another 60K each time, then picked up a S/H AMC spanish head for £100 off an engine that ran its big ends.
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
easy option is to return the car and get a refund if thats possible
fit a good 2nd hand head get your head repaired. i have a spare 10p one on the shelf off mine that has been repaired and if repaired well they are good for many more miles. or spend the money and get a new amc head fitted |
