Home > Technical > Thermo Top V remote operation
myedsore
Good day everyone.
I recently got hold of a Thermo top V FBH from a 2010 RRS which i have connected to my laptop using some of Martins Diagnostic looms and the Webasto Thermo test software.
I am able to connect using the Wbus option and can test the components however it seems the option to run it as a full blown parking heater is greyed out.
Now as I'm trying to get this to run as a remote heater that I will fit into my motorhome I'm assuming there maybe something I'm missing to get this working. I was under the impression it would be able to be tested using the thermo test software.
I am using the v2.16 however it would not connect to the v2.14 software initially until I had connected to the v2.16 first. Now it seems to connect through both.
There are no faults or lockouts.
Is it because it is a 2010/2011/2012 FBH?
Any help would be much appreciated.
I am holding out for Robinson Labs new board that he is working on at present.
Post #885438 14th Feb 2021 10:05am
grafty99
I'm running mine off an eBay W-bus signal generator in auxiliary heater mode (jumper wire setting on the little module)
Working a treat Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #885763 15th Feb 2021 7:28pm
