Home > Expedition & Overland > Laptop GPS, Maps, and route tracking
u23mt2
2002 Defender 110 Td5 Black LE Java Black
With the wealth of knowledge here I hope someone can give me a steer in the right direction.
I would like some advice on GPS and satellite mapping software. I'm looking at purchasing a Laptop based GPS setup mainly for trips to Europe and North Africa. I have had a look at Fugawi, Touratech QV, Oziexplorer and half a look at memory maps. I will need to go out and get the whole setup so it doesn’t really matter if I have to buy a specific GPS to get the system to work. The plan is to have a laptop/netbook in the front of the car (yes I have to go and buy one of these also.....). Big Cry
Does anyone have experience good or bad of any of the GPS mapping available? All I need to be able to do is see where I am (moving map), plan routes and check where I have been. The quality of the maps is quite important so if anyone has any hints for where I can find them that would also be much appreciated!!
Post #83371 8th Aug 2011 3:17am
SJM
I'm in similar situation, although not needing a laptop in the car etc. I was on an off road weekend a few weeks back with a guy who was using (I think) a handheld Garmin and then uploading/ downloading data to his laptop. I'll see if I can get his email address and get some info from him as it will help us both. Simon
'11 Defender 110XS Utility SW
'07 Discovery 3 HSE
'58 Porsche 356A (not good off road)
'59 Lambretta (not good on or off road!)
Post #85090 18th Aug 2011 7:39pm
markb110
Simon
I'll show you my set up next weekend when we catch up.
In a nut shell I have a panasonic cf 18 either mounted on the passenger side or the wife has it on her lap.
I also have a MIO 550 PDA in my line of sight as it is safer to view whilst on the road. I also find this easier to see the turns as i have the scale turned up. The laptop is good to see the bigger picture as well as planning alterative routes if lanes are shut.
Both running memory map.
I plan the routes I take on the laptop then copy to the PDA. Once home I tidy up the tracks i.e delete the road sections, just leaving the BOATS and UCR's. Once done I copy that back to the PDA so that they are the same.
Both are continually powered, the PDA by a dedicated socket and the laptop via a wired in inverter.
The laptop uses a booth tooth GPS mouse, the PDA has GPS built in through I do have an external ariel on the roll cage as it helps to fix the position quicker.
Hope this helps
Mark
Post #85113 18th Aug 2011 9:05pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
With Garmin on the laptop you will need NRoute to get a moving map Thumbs Up
Post #85126 18th Aug 2011 10:01pm
Mark_110DCPU
United Kingdom 2001 Defender 110 Td5 DCPU Chawton White
Memory Map is really very hard to beat, if you are in the UK.
However, something like oziexplorer is pretty good if you can get good quality maps as image files, as it does not reply of a digital map format, just some registration marks onto an image you supply.
I spent the last weekend running Memory map constantly with my Garmin GPS60 plugged into the serial port on my Toughbook cf18. I gave up faffing with the usb gps mouse things, and just bought the lead for my hand held. it took less than 2 minutes to get it working that way!
hth
Mark [:O|===|O:] 2001 110 TD5 Doublecab
Post #85133 18th Aug 2011 11:23pm
Glynparry25
I agree with that 100%.... but for Europe and further not so much. I am using it here in Cyprus with a map downloaded from GeoTIFF, but the map quality is pants compared to the 'OS Style' military maps I have- as a result I am using the laptop as reference and using paper maps for the nitty gritty stuff (how old school is that!)
Mark, tell me more! So if I go for Oziexplorer I will be able to scan my maps into say a JPEG and then link them into the program?
If you are buying a complete setup inc computer, I would do as I (and Mark) have done. The Panasonic range can be bought with GPS on it (which works inside the vehicle). on my CF-19 I also got GRPS so can connect to the internet. I bought mine for work as I kept on killing normal laptops and now use it for everything. 2 years down the line, 2 war zones and about 7 other countries- well worth the extra pennies Very Happy. Also has a RS232 input which is handy for diagnostic Smile
Glyn Dog Sheep
Post #85148 19th Aug 2011 6:54am
SJM
Thanks Mark - will look forward to seeing it next Sunday. At this stage I think a handheld Garmin will be fine, and I can then upload/ download and play with on the Mac when I get home. Do all Garmin handhelds record the route you have taken then? And do they all allow you to upload maps from another source? I'm off to the Garmin website later to read up, but any tips will be helpful Bow down Simon
'07 Discovery 3 HSE
Post #85175 19th Aug 2011 9:43am
Mark_110DCPU
Glyn,
Have a look on the official site - http://www.oziexplorer.com/ - however, my rudimentary understanding is that you can do exactly that, yes
I have to admit that I have never used it, but it has always been my intention to swap to ozi should I be travelling abroad and/or where digital mapping is not easily available.
So long as you can scan and/or stitch scans together accurately to make a decent area of coverage it seems like the way to go to me.
In the UK we are spoilt with the quality of mapping the OS provides. Memory map works beautifully with it, but for other areas a more flexible solution is required - hence Ozi.
SJM - mine is a quite basic handheld Garmin - I use it for walking alongside a paper map, rather than as my only naviation tool. Even the ability to stop, and have an exact (within reason) fix is a massive advantage. The moving map element could be added at a later date, and I cannot recommend the toughbook enough. Mine was acquired fairly secondhand, without the GPS or GPRS, but does have wireless. If I were to buy new, I would do the same as Glyn however! [:O|===|O:] 2001 110 TD5 Doublecab
Post #85183 19th Aug 2011 10:56am
u23mt2
So far I have the trial version of Oziexplorer and it seems pretty good Ishould probably just buy the full version and get the moving map facility working. I agree 100% the maps for the UK availible are excellent but I won't be using it for the UK much....
I did have a wee look at Memory Map and the huge bonus was the detail that the OS maps give.
Sounds like Ozi is the way forward? I did have a brief look at Fugawi maps but its quite expensive for what it is, but on the plus side you can buy maps straight from Fugawi that dont need scaled or played with to make them work???
The toughbooks are good but bulky and expensive, I was thinking of using a solid state netbook or tablet mainly coz they are small and easy to remove or stash out of sight when the car is parked. I'm interested to see if anyone has killed them in a car?
Does anyone have first hand experience of Ozi? I'm interested to see how easy it is to set up a map and input routes and track routes you are driving. I'll report back if/when I eventually get around to getting the full version.
Thanks all for the responces.
Post #85198 19th Aug 2011 12:05pm
