Home > Maintenance & Modifications > Defender 1993 Front Door Hinge Screws |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
If the hinge screw heads aren't Torx then they're more likely to be PZ4 rather than Phillips.
11th Feb 2021 2:09pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3410 |
Indeed, they are Pozi screws, PZ4 (we are talking about the screws that fasten the hinge to the bulkhead and the doors.
The screws that fasten the wing mirror are smaller, I think PZ2 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
11th Feb 2021 2:33pm |
Buckers Member Since: 11 Feb 2021 Location: Derby Posts: 2 |
Thanks to you both.
Definitely not Torx, I will look into getting PZ4 & PZ2. I will measure beforehand. All the best |
11th Feb 2021 2:47pm |
Btw, to access the screws for the mirrors, you only need to undo the door side bolts.
The nuts are not captive. But you may be able to keep them from rotating bu using a 13mm open ended spanner to save you removing the door card. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
11th Feb 2021 5:07pm |
