Home > Faults & Fixes (L663) > Foam insert bottom of screen...
Gareth
Anyone else got the foam strip at the front of the dash/bottom of screen joint fitted wonky? Mine is not fitted straight. Not a big deal but slightly annoying.
 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #883190 4th Feb 2021 3:15pm
SN
Will it move or does it appear glued in? can you use a needle or similar stabbed in it to help manouvre and rectify it?
One for powerfuluk to do a video on methinks Thumbs Up Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #883191 4th Feb 2021 3:21pm
Gareth
It’s stuck to the back edge of the dashboard. I tried to push it down, but glue seems quite strong. It’s really not worth hassling over to be honest.
If it means the dash has to come out to fix, I’ll live with it. I’d rather not have a new car with all the associated broken clips and potential rattles a dash removal might cause. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #883201 4th Feb 2021 4:15pm
J77
This is been a thing on many LR models, my Fl2 had wonky foam. 24MY 90 D250 HSE, Tasman Blue
Post #883208 4th Feb 2021 5:22pm
RRUK
Mine obviously has the foam, not taken much notice of it so far to see if it looks wonky - too busy listening out for the brake noise I get! 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #896231 6th Apr 2021 3:57pm
J77
My 90 is the same, wonky foam along the base of the windscreen. 24MY 90 D250 HSE, Tasman Blue
Post #896232 6th Apr 2021 4:02pm
Tim in Scotland
I can see about 2mm of the foam on my “old” (ie very early production) New Defender but it is very evenly applied, straight and it looks like it it something to stop the dash tapping on the glass.
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #896241 6th Apr 2021 4:18pm
