![]() | Home > Puma (Tdci) > Demand decat exhaust + Stage 1 Alive Remap |
Rye54 Member Since: 09 Jul 2017 Location: Scotland Posts: 48 ![]() ![]() |
Good afternoon,
I'm looking at placing an order with Demand engineering for one of their cat shell stainless exhausts with the sports centre silencer and at the same time getting a stage one alive remap. I've spoken with Dan at Demand and he has been fantastically patient answering my questions. My vehicle is a defender 90 2.4 tdci which is completely stock at present, the old exhaust has rusted off and I wanted to replace it with something that will last, the improved driveability from a remap is also quite appealing. However, I'm unsure what the noise of the exhaust will be, I don't want anything too aggressive sounding whilst driving up and down the quiet country roads where I live. I am told the remap does nothing to the exhaust note, does anybody have a demand exhaust fitted with the central silencer and how do they find it. I wouldn't mind a bit more of a grunt or a small amount of turbo hiss but I don't want it to be too in your face. Cheers |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
I can't comment on the sound on a 2.4, but highly recommend Demand, Dan really knows his stuff and gives great advice! James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
There's a central sports silencer option which is what I'm going to go for, I just wondered how much it moderates the exhaust note and if anyone had a similar setup and how they found it.
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80 ![]() ![]() |
there are people who say that you have to keep a certain back pressure in the exhaust and others say the opposite
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
The cat on or off makes the biggest difference. A tdci is not very loud even with all the exhaust removed, and just the cat down pipe on.
I assume you aren’t near Demand, so can’t try with/without box. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1983 ![]() ![]() ![]() |
I have the dummy cat and sports silencer, in the 2.5” and its fantastic quality.
Mine is also the 2.4 on a 110 The sound is nice and rounded when driving normally, it has a nice rasp when accelerating hard and nice subtle whoosh when changing gear, it also has a very nice purr when idling. Mine has been remapped by BAS, has the air box mod, BAS intercooler and BAS silicone hoses You will enjoy it but in the unlikely event you don’t it can always be altered ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
I’ve got a BAS remap and straight through cat back exhaust. At idle and while accelerating it is no louder than when it had both silencers. If you bury your foot it makes a nice racket but that is it. There was a very noticeable change is how smooth the engine was after doing this and it revs much more freely.
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 571 ![]() ![]() ![]() |
The exhaust "counter pressure" is very important for 2 stroke engines. 4-stroke-engines have valves and an exhaust is just counter productive and the silencers & DPF even more If want a really performative sports car, cut off your exhaust & anything in the line including your EGR |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
2.4 TDCi Puma decat with straight through exhaust.
Minor sound difference from inside the cabin. Louder from outside and more throaty, but only really when under load. Under normal driving conditions it's just a bit less 'muted'. Main difference is the audible 'dump' when the turbo waste gate gives off Can sound antisocial if you absolutely rag it all the time, but you don't buy a defender to drive it like a sportscar. Some people say decat will cause the turbo to overspool... I can only comment on my own experience in that this hasn't happened to me in the two years mine has been fitted. Overspool typically points at faulty/dirty turbo vanes. > 110 XS Double Cab Last edited by hank on 4th Feb 2021 9:30pm. Edited 4 times in total |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
On a side note, if anyone has a 2.4 cat pipe I’d be interested in buying it
Well its purchased now, and whilst I've had my adult sensible head on worrying about exhaust tone etc that may change when I get behind the wheel after having it done.
This was my thinking, I presume if I find it too over bearing the old cat could be welded/sleeved onto the stainless front pipe and fitted back in, turning it into a cat-back stainless exhaust. Like everyone who has experience with Demand, I can only praise them so far. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
i believe i have one in the wksp Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Donleguano Member Since: 13 Jan 2018 Location: Zurich Posts: 8 ![]() ![]() ![]() |
Hi Folks,
sorry for my english ![]() @Rye54 I just wanted to ask you if you have fitted the Demand De-Cat and the sports center silencer? How loud is the car now? I have a 2.4 , 110 with the following mods: BAS Silicone Hoses BAS Intercooler BAS Mapping Decat Airbox mod 80mm Intake I would like to achieve a better sound but im very unsure because of turbo overspool. I planned to keep the stock rear muffler and replace center section with sports center silencer from demand – but i dont know how loud it is then. Ist there any chance someone with this setup could drop me a soundfile or movie by whats app? thx, don
Hi Don,
I have an Alive stage 1 remap and the Demand de-cat and sports silencer fitted (no rear muffler), I would send through a whats app video of the sound but she's in bits at the moment in the garage. Like others described when I was considering the exhaust, the exhaust note change is subtle. I had the exhaust fitted first which gave a a very slight change in tone to the exhaust note pretty much regardless of revs, but it does now mean there is a subtle woosh noise when changing gear, especially if the revs are high. After the remap was done the exhaust note was still the same mostly, except in 3/4/5 when you put your foot down there's a much heartier growl comes from the engine. Overall if you drive in a civilised manor you wouldn't know it had been done, good gear changes and a steady right foot and there is no woosh noise or real change in exhaust note. Plant your foot down and the woosh noise happens in any gear and the exhaust really roars in 3/4/5. I'm presuming for the BAS intercooler/hoses you've got a stage 2 remap, I'm unsure how it would sound with that but I would imagine more aggressive. |
