Home > Technical > Door Lock Button
90roy
Door Lock Button
Is there a way to remove the door lock button/slider without breaking it?
I want to remove the door card on my 1996 90 and I cannot see a way to remove this without it snapping.
I have had the door cards off a few times over the years and always broke the lock switches.
There must be a better way surely?
Ta,
Roy 300tdi 90 1996.
Post #882845 3rd Feb 2021 8:52am
rallysteve
you need a thin wide tool which is, if possible, as wide as the bottom edge of the lock surround. You need to insert the tool at the bottom of the surround (between the surround and door card) and give it a sharp tap upwards. You might still end up breaking the bit that screws onto the door behind though as the cheap aftermarket ones tend to be more brittle, especially in the cold temperatures at this time of year.
Hope that helps,
Post #882852 3rd Feb 2021 9:11am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
try using a small piece of wood at the bottom of the slider and tap the wood gently upwards with a small hammer, Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #882854 3rd Feb 2021 9:15am
90roy
Brilliant, thanks guys.
I'll give that a go. You're right about the aftermarket ones being brittle, I may try to locate some genuine Landrover ones and see if they fare better. 300tdi 90 1996.
Post #882888 3rd Feb 2021 10:49am
Dinnu
They slide vertically up. They can be hard sometimes to push up, but doable.
When re fitting you need to be careful that the back side of it slots in, as well as the 2 little pins that clip at the bottom. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #883023 3rd Feb 2021 8:58pm
jeffersj
Just use a small piece of wood under the slider and tap the wood with a small hammer or similar until it slides up. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #883091 4th Feb 2021 9:39am
Ianh
Post #883179 4th Feb 2021 2:16pm
dorsetsmith
DOOR CARD FIR TREE FASTENER RECEIVER (THE PART THAT BREAKS IN THE DOOR CARD)SUITABLE FOR EZM500050 NEEDS TO BE BONDED IN
Post #883194 4th Feb 2021 3:36pm
