Home > Technical > Broken Heated Windscreen Connector |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
I’m hoping someone can help, had an issue with the heated windscreen working intermittently the last couple of days, did a bit of poking around and found that the plug has broken off the ribbon strip on the driver’s side. Is there any way to repair or replace this plug?
Click image to enlarge 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
24th Jan 2021 5:38pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 827 |
You used to be able to buy special glue by hat was conducting. As years ago I broke ba rear window connector and re glued it. All working after.
https://www.amazon.com/Permatex-21351-Elec...B000HBGKWE Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
24th Jan 2021 6:49pm |
