Home > Puma (Tdci) > Heater Matrix?? |
That's a good point, I'll take a look. It is however, snowing heavily here now, which is really unusual for my part of the country Darren
24th Jan 2021 9:21am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3422 |
A cheap USB endoscope camera is sometimes useful for such situations.
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
24th Jan 2021 10:30am |
So, after a bit of a further poke around and another decent drive (well, it was snowing), I have another theory:
There's no obvious loss of coolant and despite a a long run to get up to temperature and turning the heat on and off, I can't replicate the problem. As a result, I'm now cautiously optimistic that it isn't the heater matrix after all. The only thing amiss that I could find is that the passenger side 'fender' seal had fallen off. This is the short rubber flange that's clipped to the inner edge of the wing where it meets the bulkhead that's designed to divert away rainwater run-off. My theory therefore, is that rainwater is getting into the heater box itself and that it is rusty water much as 90dv suggested. If that's the case then I guess it's the least worst news as it means that I haven't got a coolant leak and my bulkhead isn't turning to dust. It's still an issue that will need sorting out but is less immediate and can wait until warmer weather. I'll keep an eye on it but for the time being I feel like I've dodged a bullet Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
24th Jan 2021 3:05pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
Have you poked the ducks beaks under the heater box to see if they are clear/dry?
24th Jan 2021 3:27pm |
No, unfortunately not. Mainly because it was snowing heavily when I was trying to look this morning. I'll have to have another poke around when it's a bit drier. Darren
24th Jan 2021 4:13pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Sounds more positive that this is not hugely serious or expensive Rgds.
Chris |
24th Jan 2021 6:21pm |
Yeah, hope so although I'll settle for not immediate, to be honest. Darren
24th Jan 2021 9:29pm |
Not specifically but somebody recently posted some very similar pictures that proved that it's nothing to do with the heater and more likely the windscreen or bulkhead seals. Haven't had chance to do anything about it other than order some sealant yet, though. Darren
1st Mar 2021 8:24am |
Norfolk-n-chance Member Since: 01 Sep 2019 Location: Usually in the garage! Posts: 80 |
Thanks, I’ll check that out “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.”
1st Mar 2021 11:53pm |
