Home > Td5 > Live feed for accessories from underseat. |
souster4 Member Since: 11 May 2014 Location: West midlands Posts: 153 |
If you take the cover panel off the fusebox under the drivers seat, and then lift out the trim around the fuses, You will see 2 eyelets that are positive lives straight from the battery.
Although I ran a brand new cable 16mm² from the battery to under drivers seat for my aux fusebox |
15th Jan 2021 4:18pm |
Paul1275s Member Since: 21 Apr 2019 Location: East Sussex Posts: 80 |
Thank you, I'll have a look! I guess straight from battery is an option but i thought it might be possible to use one of the spare unused fusible links. My accessory box is rated to max 50a so was gonna run 6mm2 cable. 2003 Defender 110 TD5 SW
2003 Caterham 7 2006 Mini Cooper GP |
15th Jan 2021 4:29pm |
