Home > Technical > Rear door central locking part unobtainable
souster4
Hi guys
In need of the bell crank to fit the rear door for the central locking. Unfortunately, I've looked everywhere online and nobody has them in stock, and their suppliers and land rover have no clue when to expect them.
I just wondered if anyone had made their own, or even have some dimensions i could have one 3d printed, or make one?
Above is the picture of the part I'm after. I'm not even sure how it fits to the door, is it like a bush inside it?
Cheers guys
Post #878632 15th Jan 2021 3:59pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
What’s the part number on that, is there not one like that on the front doors also? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #878640 15th Jan 2021 4:35pm
souster4
FQF000040 is the part number Smile
Post #878643 15th Jan 2021 4:38pm
Race.it
Yep though that was on one of the other doors also but it’s not. I was thinking of the actuator. If you do locate a supple post here as I also need one soon. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #878645 15th Jan 2021 4:51pm
Looking at the photo in this thread - https://www.defender2.net/forum/post715270.html - it wouldn'tbe too difficult to make a substitute for this, it is a very simply pivot and it looks as though one of the three "arms" isn't used anyway.
Post #878648 15th Jan 2021 4:59pm
landy andy
I’m sure you’ve thought of this, but, if they only use two of the three holes in it, and they are fitted to both doors, could you swap your left hand side one with right hand side one, if it’s broken through a rod hole, or is it broken elsewhere?
Post #878660 15th Jan 2021 5:31pm
Race.it
It’s for the tail gate not the rear side doors Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #878665 15th Jan 2021 5:40pm
landy andy
Ahhh. Sorry. Embarassed Embarassed
Post #878678 15th Jan 2021 6:40pm
landy andy
Could this work, or be made to work
https://www.ebay.co.uk/itm/152754814340
Post #878679 15th Jan 2021 6:51pm
llessur
or the P38 RR part DBP5004L
Post #878689 15th Jan 2021 7:37pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I have one on the bench since i removed the CL from the rear door, however it will go back in soon,
I'm happy to post it to someone if they can scan it for measurements for 3d printing, then send it back if this helps
other than that, i can do some measurements for you,
As Blackwolf said, only 2 of the holes are actually used.
Post #878707 15th Jan 2021 9:00pm
souster4
Thanks for your replies everyone. There's certainly some options to go at thats for sure. I think its got to be fairly similar to the original as the pressing of the door has a recess to suit the motion of it.
Post #878719 15th Jan 2021 9:35pm
souster4
Badger110 pm sent Smile
Post #878720 15th Jan 2021 9:35pm
130dreamer
I think I have a couple of spares of those.
Will have to go to the lock up to check so will be tomorrow before I can get back to you.
Post #878802 16th Jan 2021 12:17pm
Race.it
If you have more than one that you are selling can I go on the waiting list 😁, after the op first obviously Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #878805 16th Jan 2021 12:27pm
