Home > Technical > ABS Wiring info |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 |
I have found info for the question above but it has also raised another query.
The description tells that the ECM provides the ABS ECU with a signal about engine torque, throttle and type, but in the wiring it just lists this connection as throttle pedal. Can anyone offer any help on what signal is sent on the SP wire? Click image to enlarge 1989 90 4.3 V8 2012 L405 OF 2014 D4 HSE Lux (SOLD) 2015 90 HT (SOLD) @d9o.mf |
21st Jan 2021 9:51am |
