Home > Tdi > Air Fikter Compatibility |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Take the old one out and have a look.
From memory I think they are the same but a dim and distant memory is telling me the 200tdi disco filter is shorter. As long as it fits and seals then should work Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
12th Jan 2021 11:37am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2658 |
That’s a 200Tdi Defender filter. The 300Tdi Defender uses a shorter canister I believe. Or it may be that it doesn’t have the fins on it.
12th Jan 2021 12:20pm |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 360 |
Just cut the plastic off. The 200Tdi. Has more holes but the dimensions without the plastic is the same.
Click image to enlarge |
16th Jan 2021 3:36pm |
