Home > Maintenance & Modifications > Remote Battery (Jump start) Terminals
discomog
Looking to install a pair of remote battery terminals to MY15 Puma and trying to assess the best place to locate them. Front of the seat box looks an obvious place but not sure about them being damaged by passenger's feet. I'm also considering under the bonnet on the left hand side near the heater unit but obviously requires more cabling and not sure how easy it will be to route the cable from the battery to under the bonnet.
Looking for advice, ideas and suggestions from anyone who has installed them.
Please don't suggest I fit an Anderson socket as I am using a Noco Boost Lithium starter.
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #877112 8th Jan 2021 6:13pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Wouldn’t the door side of the seat box be better? Sheltered from feet and easy to access with the door open Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #877116 8th Jan 2021 6:29pm
Grenadier
I’m thinking of the same upgrade. I was thinking in this location, which I think is where Leamreject means.
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #877119 8th Jan 2021 6:32pm
Leamreject
Thanks Grenadier.
Exactly where I’m going to put mine. Out of harms way simple to connect and perfect for ease of access Thumbs Up Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #877120 8th Jan 2021 6:35pm
Leamreject
Just need to move the steering wheel to the popper side on this vehicle pictured.... must have been a Friday build Rolling with laughter Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #877122 8th Jan 2021 6:37pm
Grenadier
Rolling with laughter Rolling with laughter Rolling with laughter Monsieur Le Grenadier
Post #877143 8th Jan 2021 7:58pm
discomog
I'm confused. Where abouts is Cubbington in Italy? Defender 90XS SW
Morgan Plus 8
Post #877156 8th Jan 2021 8:51pm
Leamreject
I'm confused. Where abouts is Cubbington in Italy?....
It’s in a similar place to the battery on a Defender.... “difficult to get to but worth it when you do”
Snigger Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #877175 8th Jan 2021 10:32pm
Grenadier
What I want to know is what a Leam is, how how it feels to be rejected by one? Whistle Monsieur Le Grenadier
Post #877214 9th Jan 2021 9:35am
DSC-off
I've looked at doing this, but not got round to it. Giving other's a jump start from the Defender is a pain, getting access to the battery.
Those Blue Sea terminals seem ideal for the job.
There is very little clearance between the seat box side and the door when it is closed. If you want to fit them there, a recessed panel may be required, so the terminals don't stick out.
-On the top of the seat box, near the seat rails may be an option, but could be in the way for seat adjustment?
Fitting to the front of the seat box would be a straight forward job.
For charging I have made up leads to connect my chargers to a cigar socket inside the rear door, the usual 'Purple wire' connection described on the forum.
I run a 240v extension lead into the back, through the door seal. The charger is completely inside the Defender.
Due to short runs in the winter, it usually needs a top up charge every 2 to 3 weeks.
Post #877227 9th Jan 2021 10:40am
Leamreject
Leam is short for Leamington Spa... I’ve been rejected Big Cry Big Cry Big Cry
Happy to be in Cubbington, although it is overrun buy JLR employees, New Defenders are breeding everywhere..... Off Topic Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #877239 9th Jan 2021 11:53am
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
Have you considered the military option?
https://www.ebay.co.uk/itm/British-Militar...1195.m1851
These are used on the wolf 24v so should be capable enough.
The plug that goes with it is available but you need to do a bit of research to find one that fits, unless you go for the military one but they are pricey.
Post #877344 9th Jan 2021 8:55pm
htb2
Wales
What size Anderson plugs should be used 175A or 350A?
Post #877353 9th Jan 2021 9:49pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Htb2 - The SB175 is rated up to 280A, the SB350 up to 500A. I believe the starter motor on a 2.4tdci is rated at 300A so theoretically you need the SB350. In reality you are often only helping out the vehicle battery when jump starting, and that only momentarily. I made up jump leads with an SB175 and good heavy cable and have never had any trouble. I've seen a lot of commercial offerings built the same way. SB350 is a very large connector and not therefore very convenient if you don't have to use it.
Apologies to discomog, who said no Anderson connectors!
Post #877361 9th Jan 2021 11:22pm
htb2
Wales
Thanks SWT. That was my thoughts as well, but thought better check. Should have a made up set of short leads and one 175 anderson connector in the sheds somewhere. Just need to make up a new set of jump leads to mate to the other half of the anderson.
Post #877362 9th Jan 2021 11:28pm
