Home > Technical > Can I use this in the transfer box
souster4
As title guys, for the transfer box in a td5 defender. Mannol oils on offer
https://www.ebay.co.uk/itm/MANNOL-4L-Extra...890.l49292
Want to stick to fully synthetic, and GL4. But this oil states GL5 for limited slip diffs... is that going to be a problem?
Only other alternative just states gl4+. God knows what gl4+ plus is compared to gl4.
Any ideas guys or go for a different brand
Thanks
Post #876821 7th Jan 2021 10:40am
Joel
United Kingdom 2002 Defender 110 Td5 DCPU Santorini Black
LT230 can use GL4 or GL5 as long as its mineral EP80/90 or synthetic EP75W90 which this is, so it will be fine.
Post #876826 7th Jan 2021 10:56am
souster4
Cheers Joel.
This particular oil is states for limited slip, so has different properties to the oil for LSD. So wondering if it will still be ok?
Post #876840 7th Jan 2021 12:01pm
Dinnu
Never hear of the brand... not sure if I pay premium prices for the brand name only, or if they are indeed better blends with RnD to back up the performance.
Been bitten once with cheap 2 stroke oil.. I ran out of oil, and bought what I could find...it met the specification according to the label, but the result was huge carbon build up on the piston crown and head that once dislodged scratched the bore. So in my opinion, buy the best you can afford.
With gear oils, it is more difficult to see the performance difference. Just my opinion. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #876841 7th Jan 2021 12:09pm
Joel
souster4 wrote:
Cheers Joel.
They say it meets the standard, so it’s fine. GL5 is just a meant for higher stress applications such as LSD’s, so it won’t do any harm putting it in something that normally takes GL4.
If it helps, I’ve always used smith and Allen for my lubricants. They are a little more expensive, but I am always wary of names I have never heard before.
Post #876849 7th Jan 2021 1:10pm
Bluest
GL5 can be corrosive to certain metals that are fine with GL4. I wouldn’t use a GL5 oil in a GL4 application unless it is dual certified for that reason. 2007 110 TDCi Station Wagon XS
Post #876851 7th Jan 2021 1:16pm
souster4
Thanks everyone. All sorted 👍
Post #876965 8th Jan 2021 12:11am
This. The underlying reasoning is that the additional sulphur content of GL5 damages "yellow" metals (brass, copper, and bronze). Sulphur tends to "stick" to any metals surface and provide a nice slippery surface, but can under the right conditions cause the surface to break up on the yellow metals with seriously destructive results. The effect is likely to be more sever the hotter the oil (and LT230s do get pretty hot).
This is another of those subjects where you will now find a wide range of very different opinions on the Internet, but in general you won't find an old school mechanic or engineer who uses GL5 in any older-technology gearbox.
Post #876985 8th Jan 2021 9:09am
souster4
Cheers guys.
To be honest I was aiming more on the fact it was limited slip gl5 rather than gl5 itself.
But apparently that particular oil can be used in traditional diffs etc
Post #877016 8th Jan 2021 10:39am
Mo Murphy
Dont underestimate the ability of the wrong oil to damage bronze and brass components in gearboxes of any sort !
50 Shades of Pennine Grey
Post #877043 8th Jan 2021 1:32pm
