![]() | Home > General & Technical (L663) > How to disable the Auto Stop/Start feature? |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
You can get it to remember the setting, ie it will remain off after a restart if you have it set to off, with the IID Tool
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
dariograna99 Member Since: 19 Oct 2023 Location: London Posts: 2 ![]() ![]() |
Have you done this on yours? What IID tool do you have or recommend? I was aware of this option but have not read much about it yet, I was looking for the simple unplugging connector for the time being...
Yes done it on mine, I've got the IID BT G3, you can do the stop/start as well as quite a few other things, it's still a work in progress but have a look at this thread https://www.defender2.net/forum/topic89347.html and the main discussion thread is here https://www.defender2.net/forum/topic85281.html
