Home > Technical > Diff lock light stays on with diff lock disengaged 1984 90
familymad
Hi,
I have been tracing a fault where the diff lock light will not extinguish. The diff lock is disengaged. This the reverse of most faults I have found written up!
I removed the switch and this operated in a sense I understand, where it is normally open and if you press the switch at the end, it closes the circuit and buzzes out on my multimeter. So with the switch in my hand and ignition on, I press and the light remains illuminated on the dash. I tried shorting the wires in case the switch was doing funny things, but the dash light stays on.
So I traced the wiring back to the bulkhead. I disconnected the wiring that runs from loom to the switch. Connected my multimeter and it showed open circuit on each wire until I shorted the bulkhead end and it buzzed out fine. I also totally disconnected the wire to the switch from the bulkhead end and no change.... light still on. So I don’t think that wire has broken down due to age and is causing issues.
So I am thinking it’s from bulkhead to light where the issue is. Has anyone a wiring diagram or any suggestions? I have 12v to the switch and the light on. Is it a relay and we have an issue? Just a really irritating light to have on all the time!
Thanks 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #872264 10th Dec 2020 12:00pm
gilarion
Not saying this is your problem but the diff light staying lit is a known issue. Try this simple fix if the diff lock light won't extinguish just drive backwards a short distance and it should release the spring-loaded locking collar and the light should go out. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #872273 10th Dec 2020 12:46pm
familymad
Hi,
I have jacked up a wheel and tested to see if the lock is engaged. It isn’t. That’s why I removed the switch and stared to trace wiring. Closing or opening the circuit with or without the diff lock switch in the circuit doesn’t change the light status. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #872274 10th Dec 2020 12:49pm
jst
So there's a wire to earth, I believe it switches to earth rather than 12v Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #872321 10th Dec 2020 5:05pm
landy andy
I have the wiring diagrams if any use to you. If so pm me your email address and I can send them over
Post #872378 11th Dec 2020 12:10am
Siwynne
This happened to me last week after getting bogged dropping off firewood. It stayed on for about half a mile when I had to reverse it turned off. It bothered me while it was on but haven’t thought about until I read this
Post #872382 11th Dec 2020 6:44am
^^ That will be due to the difflock dog clutch taking a while to spring out and disengage, and is fairly normal, it is certainly not a fault (unless it is so stuck, usually through lack of use, that is never disengages). The warning light is activate by the dog clutch itself rather than the linkage, so will continue to indicate the locked state until the dog clutch moves.
Familymad's issue is definitely an electrical issue of some kind, not a mechanical issue, since it manifests itself with the switch disconnected and with the operation of the switch simulated. It is almost certainly either a broken wire resulting in a permanently open circuit or a short to ground, depending on how the switch is configured on his vehicle.
Post #872401 11th Dec 2020 10:20am
landy andy
“ So with the switch in my hand and ignition on, I press and the light remains illuminated on the dash. I tried shorting the wires in case the switch was doing funny things, but the dash light stays on. ”
But what does diff light do with switch disconnected from the wires, and ignition on?
Post #872451 11th Dec 2020 4:48pm
Dinnu
As I remember when taking my transfer box out on an early 90, the difflock switch had one wire going towards the dash, and one wire to ground on the transfercase itself. So that means that the bulb in the binnacle always gets 12V, and it switches on when the switch on the transfer case makes continuity to ground. So the suspect is a chafed wire somewhere between the bulb and the switch. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #872468 11th Dec 2020 5:53pm
Dinnu
Adding electrical schematic for around that same period. Will not be much different if any.. diff lock switch layout would also be same for petrol.
So diff lock switch is bub 'p' in binnacle cluster. The dark blue/purple is where your problem lies.
Post #872469 11th Dec 2020 6:07pm
familymad
Right, thanks all. Will print off that diagram and set to work. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #872542 12th Dec 2020 6:43am
Mo Murphy
I'd say almost certainly that between the lamp and the switch the wire is being earthed, either trapped in something or the insulation has been worn through by contact.
Have you had the dash apart, the tunnel off or the transfer box off ?
50 Shades of Pennine Grey
Post #872569 12th Dec 2020 11:40am
landy andy
So with the switch removed from the system completely and ignition on the light is illuminated on the dash?
Post #872571 12th Dec 2020 12:04pm
