![]() | Home > Technical > Crank Sensor Electrical loom plug ID |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6645 ![]() ![]() ![]() |
LR Part number is YPC909150 and you can order the housing under that part number, if it's just the housing that's damaged.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8182 ![]() ![]() ![]() |
thank you, by housing you mean the bit on the end of the wire or the bit on the sensor? Cheers
The plastic plug on the wiring loom.
