![]() | Home > General & Technical (L663) > Intelligent AWD |
Found this on the Evoque system. The fuels savings at 11.4% is hugely greater than that of the Defender system. "Land Rover vehicles are known for their all-wheel drive (AWD) capability. With the launch the Range Rover Evoque compact SUV the brand entered new territory: corporate fleets. The Evoque’s size and style made it an enticing prospect for drivers who wanted a company car with a different work-life balance. To create an innovative “Active Driveline” that could provide the efficiency fleets require without compromising the brand’s off-road capability, Land Rover partnered with GKN Automotive. The development extended the two companies’ collaboration on the Evoque’s standard AWD system. How it works The result is an industry-first: a modular AWD ActiveConnect system that improves fuel efficiency while retaining the vehicle’s traction, dynamics and off-road performance. When driving conditions and driving style allow, GKN Automotive’s intelligent driveline switches to front-wheel drive mode, disconnecting the rear axle and the major rotating masses to maximise efficiency. The GKN Automotive system has a power transfer unit (PTU) linked to the transmission’s final drive differential. This contains a synchronizer and brake that disconnect the all-wheel drive system upstream of the PTU’s hypoid gears. At the rear of the system is GKN Automotive’s Twinster rear drive module (RDM), which uses two multi-plate clutches to drive each rear wheel independently. The clutches can also disconnect the AWD downstream of the RDM hypoid gears. ![]() Click image to enlarge The benefits A dedicated GKN Automotive control unit controls the front and rear sections, continuously monitors the vehicle dynamics and driver inputs. During steady-state driving speeds above 22mph, the system disconnects the rear axle to save fuel. When additional traction is required, within 300 milliseconds, the rear wheels are reconnected. In addition to the disconnect function, GKN Automotive Twinster technology also acts as an electronic differential, vectoring torque to optimise grip, traction and stability. The co-development of the Active Driveline achieved a significant reduction in driveline spin losses, which contributed to an improvement in fuel efficiency of up to 11.4%, depending on the model. The step change in vehicle efficiency and dynamic performance set a new industry benchmark for this type of vehicle." https://www.gknautomotive.com/en/insights/range-rover-evoque/ |
The system referred to in the earlier image ~ IDD, sounds identical to that used in Jags.
THE UNIQUE INTELLIGENT DRIVELINE DYNAMICS (IDD) Jaguar’s uniquely capable automatic AWD system is available on the iconic F‑TYPE, the award winning XF and XE saloons, and Jaguar’s performance SUV, the F‑PACE. The system has been engineered specifically to intensify the experience of driving a performance car in all weathers, on all surfaces. There are two main features of AWD with IDD that, when combined, set it apart from any other system. ![]() Click image to enlarge "To transfer torque from one axle to another, the system uses an electro hydraulic multi-plate wet clutch, controlled by a centrifugal electro-hydraulic actuator. Together these technologies shift the precise amount of torque needed in as little as 100 milliseconds. Even a full shift of power from 100% rear to 100% front takes just 165 milliseconds, and happens seamlessly. All the driver notices is outstanding handling in conditions any other car would find challenging. The hydraulic system has the added advantage of generating less mechanical wear and so requires less maintenance than other systems." https://www.jaguar.com/owners_internationa...e/idd.html Last edited by Supacat on 11th Feb 2021 7:08pm. Edited 1 time in total |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 436 ![]() ![]() |
They don't mention the drawbacks...
I've seen cars crashing with this kind of system on the German highway, Audi Quattro 's or full time 4wd didn't have any problems keep the line safe and straight with parts of ice or heavy rainfall / debris. It always will be to slow to engage.. Just my 2cents. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3429 ![]() ![]() |
My Velar has IDD, it’s a good system. Responds quickly to the changing terrain, it’s doing well at the moment getting me through the snow we have at the moment. 24MY 90 D250 HSE, Tasman Blue
I think Jaguar need to change their copy:
"it’s important to highlight that AWD is not a term that’s fully interchangeable with four-wheel drive (4WD). 4WD is typically reserved for very serious off-roaders, splits power evenly between all four wheels, and offers very low gear ratios that are driver-selectable. AWD is refined and sophisticated, actively shuffling power from front-to-rear in milliseconds, its adaptability better suited to the higher speeds road cars tackle." ![]() Click image to enlarge https://www.jaguar-me.com/en/about-jaguar/...range.html |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
It does the reverse in the defender by disconnecting the front axle where as the Evoque disconnects the rear axel. I wrote an update to the warning light that appeared on my defender yesterday in the faults section but in a nutshell no faults were found in diagnostics test so hopefully just a one off glitch because as you can see I had the TR setting on grass, gravel, snow mode to give me control on the snow but it decided to give me a warning and 2WD ![]() |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Does setting the TR to “Auto” instead of one of the preset settings make any difference? Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Hi Tim, I thought only TR2 has the auto setting?
So you don’t have TR2 then........ hope I’m not going to have to change cars to find out as it came a standard on my First Edition 110 D240 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Think it comes standard in 110 first editions but not the 90
It seems other vehicles with the same/similar components are having issues:
SSM 75152 ![]() Click image to enlarge And this one does relate to the Defender: ![]() Click image to enlarge |
Philip Member Since: 09 Mar 2018 Location: England Posts: 510 ![]() ![]() |
They’re fixed torque split transfer boxes.
Thanks. I have this problem in the faults section of the group with more detailed info of what is happening.
Curiously similar.
"multiple Bronco Sports have overheated after a few minutes of tackling a small hill or hooning around in the sand. In every case, the compact crossover flashed the 4WD Temporarily Disabled message before entering limp-home mode. The Power Transfer Unit, also known as the twin-clutch rear differential that enables AWD whenever needed, is the subassembly that overheated in both scenarios. What comes as a bit of a surprise is that Ford offers a PTU cooler in the Bronco Sport Badlands, liquid cooling that isn’t up to the task of keeping the power transfer unit within the recommended temperature range. Ford Bronco Sport " https://www.autoevolution.com/news/2021-fo...57682.html ![]() Click image to enlarge Excellent article on some of the issues these AWD systems with clutches have to manage: https://jalopnik.com/multiple-ford-bronco-...1846450499 |
