Home > General & Technical (L663) > Underfloor conversion, possible?
Page 4 of 4 <1234
Nuclear Nick
Do you know the all up weight of your conversion and would it be a factor in loading the vehicle up to the maximum permissible?
Post #1026558 2nd Mar 2024 9:10am
JackW
United States 1998 Defender 90 300 Tdi SW Coniston Green
The metal frame with wooden panels weighs about thirty pound and the battery weighs about 65 lbs. The Redarc units probably another ten at most so the whole thing is about 110 lbs. With the weight capacity of the four cylinder a lot higher than the hybrid versions it won't even be noticeable with the air suspension easily compensating for it.
Post #1026745 4th Mar 2024 1:49am
Page 4 of 4 <1234
