![]() | Home > V8 > Rover v8 exhaust manifold woes |
muddypaws Member Since: 22 Jan 2013 Location: Leicestershire Posts: 122 ![]() ![]() ![]() |
Sorry - if I'd only cleared out the garage during the first lockdown!! Richard
Defender 90 SVX |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 867 ![]() ![]() ![]() |
Muddypaws, I may be interested in the manifolds if you still have them? 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
Ranger 6 Member Since: 17 Jan 2019 Location: Yorkshireman trapped in a Surrey postcode Posts: 211 ![]() ![]() ![]() |
Your engine is obviously much newer than mine as knock sensors hadn't been invented when mine was built ![]() However, my recent experience fitting the manifolds you've chosen has been a good one. My wheezing old 3.5 has been rejuvenated and now breathes so much better after fitting them. I have gone for a std steel system from a TD5 with RRC downpipes. Not perfect as it took a bit of fettling to connect everything up. Anyway, since fitting I have read that these manifolds are the best Rover ever made for this engine (3.5/3.9) and compete for power with tubular versions. Mine now pulls well in fifth gear, which is effective timely an overdrive, fuel consumption has improved and it sounds so much better. 90 V8 CSW - 1988 |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
That is good to hear Ranger 6. They certainly fit with a lot more room between them and the chassis rails.
They arrived intact promptly through the postal system. I paid a little extra to have the flanges still attached, as I may end up making the connecting pipes to the rest of the Double-S system, and using the existing flanges could save a bit of time making some new ones. ![]() Click image to enlarge In hindsight, why would the seller cut the pipes off rather than remove them from the manifolds? Because they are well welded together would be the answer... Out with the penetrant spray, a large breaker bar and some wishful thinking... ![]() Click image to enlarge A morning spent with the wire wheel then cleaned them up to an acceptable state. Only one stud had come out with the nuts, so the next task would be to work out how to remove the remainders. ![]() Click image to enlarge Out with the Irwins (fantastic tool), but inevitably some of the studs still broke off. Fortunately there was just enough stud left to still grip with the Irwins, and a bit of heat to help with the removal. ![]() Click image to enlarge A coat of high temperature paint made them more presentable. Don't know how long the paint will last, but the black paint seems to have the highest temperature rating, so we'll see. I also got the 'EFI' version of the manifold gaskets. Not sure why Land Rover changed from the one-gasket-per-port type to these multi-layers metal gaskets, but being connected together made them a bit less fiddly to fit. ![]() Click image to enlarge Then I could finally fit them. Way more room between the chassis rails, as you can see. ![]() Click image to enlarge ![]() Click image to enlarge The other side also looks like the exhaust might clear the starter solenoid a bit better too, perhaps an exhaust wrap will be all the protection needed. ![]() Click image to enlarge The next job is to work out how to connect manifold to the remainder of the double-S system. As you have already suggested I could just get the Range Rover downpipes, but I don't think they'll work with the tubular gearbox crossmember? Currently contemplating stretching my fabrication skills with one of these: https://gizfab.com/product/2-1-exhaust-collector-jig/ which allows you to put your tube into, and have a easy straight edge to cut through, allows you to build a y-piece. It looks fairly straight forward in the video: although I don't have a band saw at the moment. 2005 Td5 90 XS 1989 V8 110 CSW |
"at the moment"
![]() That all looks like it's coming together very nicely. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Having had a double S exhaust system on my 110 v8.
The entire system was nothing more than a festering pile of dog excrement. It didn't fit, anywhere, the welds failed quite quickly and their response to my complaints were, bring it to our workshop and we wil sort it out. Not really practical when their workshop is 320 miles away and the welds have failed on the LH manifold. I went to PD Gough in Nottingham and had a system tailor made by them. The comparison was laughable and their opinion of double s was unprintable. https://www.pdgough.com If Nottingham is too far away, try this outfit. https://www.powerflowexhausts.co.uk It is not a Defender, it is a One_Ten |
If I can get it to the point where I can drive it and get an MOT, then I can get it to somewhere in the future to make a nice one, such as Griffin Performance http://www.griffinperformance.co.uk/.
Having been working all day on the car today, I am doubting my ability to actually get this vehicle finished. I really want it running this year, but well... its not going well ![]() 1989 V8 110 CSW |
No, mine didn't. I had to swap the crossmember for a discovery one with the cranked ends. 90 V8 CSW - 1988 |
