![]() | Home > Technical > TD5 Squealing |
Joel Member Since: 18 Oct 2020 Location: Rotherham Posts: 76 ![]() ![]() ![]() |
Morning folks,
My TD5 has a squealing noise - seems to happen when accelerating, and then when you turn it off, there is a short squealing noise. Is it likely to just be a belt, or could it be bearings in something? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2962 ![]() ![]() |
Exhaust manifold. Maybe
Lovely. Do Defender TD5's suffer the same manifold warping as the Discoveries? It does feel a little down on power sometimes, so i wonder if it is a manifold leak causing lack turbo. Thanks. |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
Yes they do, unfortunately. Depending on the size of the leak it could in theory reduce boost pressure. Main symptom when my old Td5 had the same problem was the whistle/squealing sound. Dave
Green Goddess - 1998 Defender 110 300tdi |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
There is a good troubleshooting article in LRO International this month, especially warped manifolds and broken studs. Jeff
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5824 ![]() ![]() |
Check at either end of the exhaust manifold for soot or loose/broken studs.
I don’t think it’s manifold, I can’t see any obvious signs of an issue.
I am beginning to think it’s either belt related, or pulley / tensioner. Seems to be worse after a bit of water, so am guessing a belt is slipping or a pulley bearings are shot. |
Drive Belt tensioner or idler or alt bearings are shot. remove belt and check each bearing
