Home > Maintenance & Modifications > sump guard
the shepherd
United Kingdom 1999 Defender 110 300 Tdi HT Keswick Green
sump guard
I am looking for a sump/steering guard for my 110 300tdi with access or quick removal for when I change the oil filter so as I don't have oil all over it - anyone know of such or recommend a decent one that is more than 6mm?
Post #864279 29th Oct 2020 5:26pm
jst
do you mean a combined steering and sump guard? not sure i know of any or even know of any dedicated sump guards. plenty of steering guards out there and likewise various different front axle guards out there too. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #864297 29th Oct 2020 6:29pm
the shepherd
I have a diff guard but now need a steering guard probably not the sump....
Post #864306 29th Oct 2020 7:05pm
jst
Quite a few out there. Some offer good protection, some offer great ploughs, and some look good.
4 chassis mounting points, room for recovery rings on chassis, 3 piece assembly, tabs to pick up on steering damper mount(unused one on drivers side) reinforcing on rear of main guard would all be my search criteria.
Or, bolt/weld a protective loop on the chassis in front of the steering box shaft and fit hd sumo bars from Gwyn Lewis.
Also consider boxing in track rod if you drive in areas with stumps/brash or rocks. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #864321 29th Oct 2020 8:05pm
the shepherd
thanks I will follow up your suggestions Smile
Post #864379 30th Oct 2020 8:36am
