Home > Maintenance & Modifications > 2” Receiver drop plate problem
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Not long ago, I fitted a masai4x4 NAS rear step with a 2 inch receiver hitch. Good bit of kit, no more skinned shins when loading stuff in the back, however, I will at some point want to tow my Sankey with it, so I purchased a terrafirma drop plate.
The problem is that the hole for the retaining pin doesn’t line up with the one on the step. with the drop plate fully pushed in, the hole on the plate is about 20mm further forward than the one on the step.
As indicated by the red circle:
My question is, would it be safe to just drill new holes for the pin to go in or would I be risking the integrity of the thing by having too many holes in it?
Thanks
Post #863877 27th Oct 2020 7:10pm
Bluest
Personally, I think it would be fine as long as you’ve got about 1 holes diameter worth of metal between the 2 holes. 2007 110 TDCi Station Wagon XS
Post #863880 27th Oct 2020 7:28pm
Avelingporter
Not a direct reply to your question. However I also tow my Sankey with a drop plate. But I use it the same way up ( or upside down if you like) as your photo, so it raises the nato hitch to the correct mid crossmember height. It works well, just a slight fiddle to open the nato hitch under the spare wheel, but you do get used to it.
Post #863881 27th Oct 2020 7:36pm
BuckBlu110
That’s how I wanted to use it, that way it almost sits at the same height as if it was mounted on the crossmember.
Unfortunately, once drilled, I’m not sure if there will be that much material between them Sad
I’ll have to have a proper measure up in the morning when I’ve got some decent light.
Post #863888 27th Oct 2020 7:55pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
If you have enough space between your receiver and drop plate, then I would cut the end off to make it go in further.
It is better to support the drop plate as close as possible to the receiver.
Depending on what is preventing the full insertion, could mean you can just cut some of the excess off.
Post #863898 27th Oct 2020 8:40pm
jst
When you say fully pushed is that limited by the vertical plate or the length of square tube? If latter cut off 20mm from tube., if former then drill another hole. If space between hole centres is deemed too short weld up first hole but I doubt in reality it will be a problem. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #863901 27th Oct 2020 8:50pm
BuckBlu110
It’s limited by the welded support at the back on the plate.
This:
Of which I’d rather not mess with if it’s structural.
Hopefully if I’ve got enough material for a new set of holes.
Post #863910 27th Oct 2020 9:19pm
bear100
Had the same issue with mine, I took an angle grinder to the bit that strikes the receiver which is a negligible amount and won’t cause any issues.
But looking at yours you have a slightly different brace 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #863911 27th Oct 2020 9:21pm
BuckBlu110
Apologies for the pants photo, but I’ve marked roughly where the hole on the receiver lines up with the drop plate. This is with the plate tight up against the step.
So if drilling is an acceptable method, could I drill the hole further away from the plate so there is more material between the holes? but this would mean it would make the plate further away from the step.
Or would it be better to drill where the mark is and keep the drop plate close as possible and weld up the old hole as JST suggests?
In reality there’s probably only 15-20mm difference between each method.
Thanks for the input so far.
Post #863934 27th Oct 2020 10:34pm
Bluest
I would say drilling it in the fully home position is too close the original hole. There may be a risk the pin could break through under a heavy load. It might be fine, but it just looks too close for comfort to me. 2007 110 TDCi Station Wagon XS
Post #863940 27th Oct 2020 11:03pm
Definitely pull the drop plate out a bit so that you've got a decent amount of material between the holes. Being 20mm or so further out won't make any difference to the plate. Darren
Post #863944 27th Oct 2020 11:17pm
There's no risk of the pin "breaking through" because the plate can't be pushed further into the receiver.
If all you're towing is a Sankey/Penman drilling the second hole should be fine.
Post #863947 27th Oct 2020 11:23pm
jst
as Blackwolf says pulling the trailer it still has all that material to the front of it. the trailer pushing the vehicle - it cant go any further in if its tight against the reinforcing bit anyway.
reality is it could be a slotted hole and i doubt it would fail, it would be awful to drive with and not a good idea as you would have the 30mm movement every time you brake or pull away but the point i am making is it wouln't break
if it was mine, i would weld up the first hole, sheet ali behind and plug each hole, then drill the front hole with it tight up together. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #863981 28th Oct 2020 9:13am
BuckBlu110
Thanks for the input everyone. I’m probably coming across a bit pedantic, but I’ve seen the results of a towing accident and have no intentions of being involved in one. In 15+ years of towing, I haven’t personally had an incident, so I must be doing something right.
As I said, it’ll only be my Sankey that I’ll tow with this, my td5 does all the hard work with horse/stock boxes and flatbeds these days, so a relatively easy load by comparison.
Post #863989 28th Oct 2020 10:03am
I'm pretty sure that Safari-Equip would make you one either without a hole at all, for you to drill your own, or with a hole in a position you specify.
They did a fine job on a custom one for my front receiver, to my particular dimensions to clear the front winch.
Post #864000 28th Oct 2020 11:16am
