Home > Td5 > New head install
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
New head install
For the last month i’ve been smelling a whiff of rich diesel smoke on startup on cooler mornings.
Last week I did some checks, no oil in ECU, everything looked fine under the hood until I found an extra 4 litres of diesel in the sump....😢
I now have a very expensive and heavy Turner Engineering crate enroute across the Atlantic at the moment.
Does anyone have any tips or pitfalls I should avoid? Copperslip on the glow plugs?, headgasket fitted dry?...Anything else?Ive done several head gaskets and head changes in the past, but never on a diesel. I have the paper manual and have been doing a little research online, but thought I better ask the experts before I start pulling the old head this weekend. Is the head really so heavy that you require an overhead lift like shown in the manual?
Patrick.
Post #863334 24th Oct 2020 2:22pm
4RF RDS
No you don’t need a lift. Why a new head? have you determined its cracked? It could be leaky injectors? A Td5 head swap is pretty simple. Lots of vids on line. Since you’ll have a new head you won’t have to worry about the dreaded broken stud in the alu head. You might also consider a Wurth Stud kit, copper nuts and maybe consider de-webbing your manifold as well as a new FPR and glow plugs while you are at it.
Good luck. If you find yourself in a pinch reach out as I might be able to assist
https://www.ebay.co.uk/itm/X10-LAND-ROVER-...Sw9R1fOvne 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #863350 24th Oct 2020 3:53pm
Justtellme
Thanks!
Just ordered those new studs....I had already ordered new glowplugs as well.
I will let you know how it goes.........
Patrick
Post #863359 24th Oct 2020 4:21pm
You don't say if yours is a 10P or 15P (or later) engine....
If it's 10P then get some steel head dowels (2x) to replace the plastic rubbish.
Post #863369 24th Oct 2020 5:31pm
4RF RDS
☝🏻 That is very good advice Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #863399 24th Oct 2020 9:09pm
Justtellme
Its a 15P.
Ordered new dowels anyway just in case.....because I am close to the change over serial number and they were relatively inexpensive.
Patrick
Post #863406 24th Oct 2020 9:53pm
Justtellme
Cant fault Turner for speed of delivery.
Ordered Friday morning. DHL dropped it off an hour ago.(Monday afternoon....)
Patrick
Post #863729 26th Oct 2020 10:27pm
dorsetsmith
top marks Turner and dhl Thumbs Up
Post #863733 26th Oct 2020 10:37pm
4RF RDS
DHL is stealing international shipping from FedEx and UPS, better faster cheaper 👍🏻 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #863741 27th Oct 2020 1:06am
excossack
Is it still an AMC head? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #863788 27th Oct 2020 11:47am
Justtellme
Yep,
AMC head, AMC head bolts. Elring head gasket, hylomar ( though it looks like tube that needs a special gun to use?)
I sprung for the “genuine” seal and bolt kit,( new bolts for rocker shaft, injector seals, copper washers, cam plugs..etc..) but what came looks like aftermarket and was not in a LR green box...and they threw everything into a plastic bag including the injector O rings which ended up wrapped around sharp bolt threads. I wont be using those now.
Rest seemed OK.
Now need to find a few days to execute the swap.
We had snow this morning and the wife wants her parking spot back in the garage.
Patrick
Post #864134 29th Oct 2020 1:55am
excossack
I had an AMC head (10p) around 8 / 9 years ago and still good as gold. 1999 Defender TD5 110
Regards
John M0VAZ
Post #864158 29th Oct 2020 8:09am
Podrob
I fitted an AMC to 15P engine 10 years ago, still going strong
Post #872925 14th Dec 2020 6:55pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I like this comments but what do they tell us?
Land Rover put one an original one on mine in the factory in 2003 and it is still going fine.
So does this say Land Rover heads are better? Twisted Evil Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #872984 15th Dec 2020 7:56am
excossack
What I am saying is the AMC head that replaced my failed LR head is still working fine. Mine is a 10p 19999 engine variant. 1999 Defender TD5 110
Regards
John M0VAZ
Post #872996 15th Dec 2020 8:41am
