Home > Puma (Tdci) > Loss of power.
Coze
Loss of power.
My Defender Puma 2.4 sometimes when driving all of a sudden loses power, and will slow right down, due to lack of power. When you stop, the engine continues to run. I switch the ignition off, then restart the engine and the engine runs on full power again, so turning off the ignition and starting again is effectively resetting something. Does anyone have any idea what is causing this, or experienced a similar fault.
Thanks. Forgot to mention there is no engine management light activation, so no fault codes.
Post #861561 14th Oct 2020 5:53pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Have a look at the posts about the vcv valve on here. Thumbs Up
Sounds suspect.
Post #861567 14th Oct 2020 6:04pm
Coze
I replaced the vcv valve last year, as the defenders idle speed was very erratic, replacing this valve solved the idle speed problem.
Post #861570 14th Oct 2020 6:14pm
The first thing to do is check what if and DTCs are stored in the ECU, otherwise it's just guesswork.
Post #861575 14th Oct 2020 6:25pm
jst
As above check codes.
What conditions does it occur under? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #861578 14th Oct 2020 6:28pm
Stacey007
Mine did this just randomly lost power,
No fault codes, nothing, all dials go off then sometimes would restart on its own other times I restart it.
Could do it 3 times in a 20 mile trip or once in 3 months...
Mine was a new ignition barrel. Changed this and no issues since Thumbs Up
Post #861582 14th Oct 2020 6:47pm
Coze
What conditions : Normal driving, happens randomly can be over a month and no issues, then twice in a week, dealership hopeless as no fault codes therefore not interested. I am completely bamboozled, as it goes like a train after you have stopped at the side of the road and restarted it.
Post #861604 14th Oct 2020 8:02pm
Stacey007's reply above has identified a very likely culprit. Fiddly to fix but not expensive. Darren
Post #861612 14th Oct 2020 8:21pm
Grounding points being loose and or battery clamps is another possibility, an easy enough thing to check at least and free.
Ideally some Dielectric grease too, and checking all main HD fuses are secure.
MAF and Map sensors are clean, and maybe even the alternator live stud too.
The electrical side can have a significant impact on the performance due to the fuelling system ECU etc.
I expect the above posts maybe very possible and likely even to be the issue. But the things Iโ€™ve suggested are worth checking just in case and wonโ€™t cost anything.
Take a look at the air filter too. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #861640 14th Oct 2020 9:33pm
