Home > Puma (Tdci) > P0101-17 Fault right after remapping
jbullis
United States
This morning I installed a BAS remap, on the first trip I was getting the P101-17 fault, then going into limp mode. Reset and went right back again.
Went home and reset it map back to standard recovery and go the same code. Has anyone else had the same experience. I read that may be a cracked hose. I've drove the truck all week with before the remap and never had a problem. Can someone point me in the right direction?
Thanks
Post #860877 10th Oct 2020 5:09pm
PCM
Mine had the same fault but only after a few days of whooshing sounds. Turned out to be a split intercooler hose.
Did you change the hoses at least when you did the Remap? Chances are the hoses were on the verge of going and the remap just tipped them over the edge.
If you have a remap I'd suggest you change the hoses anyway as sooner or later they will split.
Post #860880 10th Oct 2020 5:43pm
jbullis
United States
I didn't change my hoses. The truck on has 20K miles on it. The short hose that cause the most problems look ok. I may have to take the hoses out to inspect. I was hoping not to have to do that.
Post #860882 10th Oct 2020 5:48pm
PCM
Mine was the top hose. Luckily the easiest one to check. 😏
Just out of interest did you go for the 150 or 170 map?
Post #860889 10th Oct 2020 6:08pm
jbullis
United States
170 hp
Post #860894 10th Oct 2020 6:28pm
PCM
Thumbs Up then even if the fault isn't the hoses this time I'd suggest you buy the silicone ones asap. And probably an intercooler. Mr. Green
Post #860895 10th Oct 2020 6:33pm
jbullis
United States
The truck already had the BAS intercooler on it...
Post #860898 10th Oct 2020 6:39pm
trailbear
Perhaps it would be an idea to contact Pete Bell himself, he is very helpful and may be able to help you out.
Post #860970 11th Oct 2020 2:10pm
jbullis
United States
I have been working with Pete, I posted this post before he responded to me. He has been fantastic, helping me problem shoot. The bad thing is that I just can't drive to his shop, I'm across the pond... lol
Post #860983 11th Oct 2020 2:35pm
trailbear
Yep, I can see that being an issue🤔
Post #861011 11th Oct 2020 5:37pm
