![]() | Home > Tdi > Electric windows, alarm and central locking |
Francisco Member Since: 25 Sep 2020 Location: Parana Posts: 10 ![]() ![]() ![]() |
Hello.
I am new here and before posting I did a search on the forum and did not find the answer to my question. At least I couldn't find answers to my specific questions. Furthermore, I can't even send private messages to Forum goers. I have a Defender 90 300 TDI (model year 2000). This generation has no electric window and no electric lock. The only item that was sold as an option was the alarm, but this Defender has no alarm panel. What I want to do is put an alarm panel, electric locks (central locking) and electric windows. I want to follow the factory standard. For the windows I will use CUH000082 and CUH000092 parts For electric lock I will use parts FUD500020 and FUD500030. But I had several doubts. Firstly, there are a multitude of models for alarm panels. I didn't find any technical material regarding the alarm panels, so I don't know which one to choose from the countless ones available. (number "1" in the 2 diagrams.) Not to mention other accessories such as coil engine immobilizer, key fob reciver, spider unit assembly immobilization https://www.lrworkshop.com/en/diagrams/lan...stem_52799 https://www.lrworkshop.com/en/diagrams/lan...stem_44911 The internal panel of my door is the MWC8270 (photo attached). I'm not sure but I believe that this model is not compatible with the electric window. If I'm wrong let me know. If I change it will be for the BDO710020. So I ask if this panel is compatible with the electric lock. ![]() Click image to enlarge There is also the question of the electric lock (FUD500020) I don't know how they are attached to the door. In the diagrams the lock appears "floating in the air". It is not informed which components are used to fix it. (component number 30 in the 2 diagrams). I don't know exactly where and how it is install https://www.lrworkshop.com/en/diagrams/lan...0227_52671 https://www.lrworkshop.com/en/diagrams/lan...nism_44826 Another issue is the wiring used between the door and the body. Would it be LR016316? In addition to the aforementioned wiring between this lr 016316 there must be wiring q which connects it to the central. What would be the code for this wiring? When installing the wiring, it will be necessary to make a cutout in the casing front door. How was this opening made? Does anyone know what is the code for this internal door panel ?: https://www.defender2.net/forum/topic73682...al+locking As you can see, I am lost so I am grateful for your cooperation. (If my translation was not clear enough let me know) TY |
