Home > Tdi > Fuel starvation under max load
benniferj
Hey all
Issue that is confusing me quite a bit and unfortunately hard to diagnose on the drive!
Car: 200tdi Defender engine in 90 with under drivers seat fuel tank
background: Recently changed fuel tank for new one. New in tank sender. New fuel filter.
A few times when going up an extremely steep hill on an off road site, or actually thinking about it, a couple of times on the flat dragging some incredibly heavy tyres around, when revving with the vehicle essentially being very heavy and needing a lot of power from the engine, the vehicle will try and stall. Starts spluttering, if I keep foot to the floor it will stall, if I back off it will normally just about keep going until I load it again and the same happens again. If I keep the foot to the floor it will stall and then be a pain to re start and sit there turning over with no fuel
When this happens I see my digital voltmeter essentially 'reboot' and show a " -- " value for a few seconds which shows it has lost power. Apparently my headlights flick on and off too. This made me think that for some reason I was losing electrics and thus my fuel stop solenoid was losing power and clicking in and out rapidly, dropping fuelling. I have rigged the fuel stop solenoid directly from my aux fuse board feed bypassing the main dash looms and this has not changed anything.
I did think that when dragging tyres that maybe it was electrical, with the jolting of scrabbling for grip was vibrating a loose connection around. However a very steep, but smoothly attacked climb at the weekend, the car was definitely not bucking around or scrabbling and the sheer load or angle or intensity of the climb gave me the same spluttering engine.
What is confusing me is the lack of fuelling and the flashing lights. It still makes me think the stop solenoid is clicking in and out. What would be the link between these factors that makes sense? A dodgy fuel breather, filter or in tank sender would make me expect the spluttering but doesn't explain flashing electrics???
I can rev the car and hold on the limiter on the drive and it has no issue at all...
Thanks for any help! Insta: @thebenjordan4x4
Post #860000 5th Oct 2020 8:52pm
Mo Murphy
Knackered alternator bearing causing alternator to seize ?
50 Shades of Pennine Grey
Post #860006 5th Oct 2020 9:54pm
benniferj
Not sure why that would cause mis fuel? Insta: @thebenjordan4x4
Post #860020 6th Oct 2020 5:47am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I know of a 300tdi that when a new fuel tank was put in it would randomly splutter and occasionally cut out, turned out there was a bit of paper in the fuel tank going over the pick up. Worth checking tank is clean 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #860021 6th Oct 2020 5:50am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Not sure about the electrical issue but fuel starvation could be the fuel lift pump giving up or blocked.
Post #860022 6th Oct 2020 5:58am
yostumpy
breather vent in filler cap blocked, causing vacuum.? 'Volvo XC 70, taking the rough with the smooth’
Post #860128 6th Oct 2020 6:41pm
benniferj
Thanks, its crossed my mind to swap out the lift pump as its simple and cheap - and I did wonder about the breather being blocked maybe causing that.
Can anyone try and explain the link between the electrics flickering while the spluttering happens? Thats the bit thats baffling me and made me think it's electrical rather than fuel - the electrics killing the stop solenoid of course as a byproduct... Insta: @thebenjordan4x4
Post #860184 7th Oct 2020 6:04am
jst
Mo did try.
Take the aux belt off, whats the alt bearing like?
Are feed and return pipes connect correct way around?
I would suggest alt loading system as mo did, or fuel blockage, if alt is eliminated start looking at fuel and what you have changes Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #860191 7th Oct 2020 6:59am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Possibilities
Alternator as stated
Breather to fuel tank blocked with Censored and/or weak lift pump
Blocked fuel sedimentor (if it has one)
Blocked fuel filter ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #860397 8th Oct 2020 12:10am
jst
Did it do it before tank change? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #860493 8th Oct 2020 5:00pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Leave the fuel cap off, =try,, then run a live from battery to stop solnoid ,=try , my moneys on lift pump,,,,i did fit a new fuel sender once ,and it hit the bottom of the tank, i cut 5 mm off pick up pipe, , ]
Post #860520 8th Oct 2020 6:57pm
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
My money's on the lift pump
I had a 300 tdi disco with a delphi lift pump. There's a screw in the centre of the top cap, so you can take the cap off to clean the filter strainer that you don't know is there Rolling Eyes . I had similar symptoms when the strainer was blocked with goo.
Post #860541 8th Oct 2020 8:37pm
jst
hes not been back, maybe its fixed.
if it wasnt there before fitting new parts, i think the filter is wrong or more likely the pickup is squished into the bottom of the tank.
if fault was there and new parts were trying to resolve it then lift pump gets my vote. a good fix and upgrade is an electric one RRC lift pump, makes priming easier too. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #860543 8th Oct 2020 8:47pm
Mo Murphy
I've fitted an electric facet duralift to my 200 because of the poor quality across the aftermarket suppliers of mechanical lift pumps.
Post #860551 8th Oct 2020 9:13pm
Dave T
Is there a thread or details anywhere on this? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #860582 9th Oct 2020 7:51am
