Home > Technical > 1984 drive flange washers
familymad
I’m looking for a part number. Took all the drive flanges off my 90 and nipped up the bearings. After replacement I re attached the circlips to the ends of the half shafts. 2 of them had spacing washers to take up any slack/play and 2 didn’t. The ones that didn’t had 1.5 mm of lateral play towards the diff or out towards the flange.
Does anyone know a part number. They are very thin but large washers.
Thanks 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #859981 5th Oct 2020 7:34pm
dorsetsmith
Post #859982 5th Oct 2020 7:44pm
familymad
Good post thanks. Hmm, I have to order a range then 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #859983 5th Oct 2020 7:46pm
Retroanaconda
There’s a range of sizes as you use them to set the end float of the CV joint.
Post #859985 5th Oct 2020 7:55pm
dorsetsmith
End play should be between 0.08 to 0.25mm
Post #859987 5th Oct 2020 7:58pm
familymad
Ohh this is a new learning experience for me. Sounds like a need to use a set of feelers or a dial gauge.
Thanks all 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #859991 5th Oct 2020 8:02pm
And they're only fitted at the front.
Post #860003 5th Oct 2020 9:20pm
familymad
Which is how it is. Ok, I won’t be adding them to the back after all. Why the slack at the back? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #860025 6th Oct 2020 7:12am
Because it doesn't matter at all if there is float on the rear shafts since there is a linear spline at each end, They are fitted at the front because the centre of 'flex' of the front CV needs to aligned with the axis of the swivel pins, which occurs when the stub shaft is pulled fully into the hub. The shims are provided to take up manufacturing tolerances and small differences in position of the hub etc.
The shims were, as far as I know, not fitted on later vehicles and I think it highly improbably that LR sharpened up on tolerances, so I presume in the end they either decided it didn't really matter or decided that if the CVs wore at an accelerated rate it didn't matter, it would just result in a bit more dosh from the customer.
Post #860030 6th Oct 2020 7:47am
donmacn
Wow.... it's a strange world. I posted a thread about these shims only yesterday, after a search, but this didn't come up. I don't know how this thread passed me by.
Like familymad, this is relatively new to me.
I'd puzzled over the lack of shims on the rear - and here's my answer! But wouldn't/doesn't float here cause issues with rear disc brakes? Too much float contributing to pads being pushed back, and a longer pedal? Caliper attachded to axle; hub 'floats' on axle; too much float = pads get pushed back = poor pedal? On the other hand I think I'm missing something, and that properly adjusted bearings will keep float here to an absolute minimum. Every day is a school day.
I assume by "later vehicles" not having them, we're not talking about a 1994 Tdi...?
On the front, I've sat back and visualised the plane/axis of the swivel pins, and the CV flex and I can see that. Then I thought - what if the shims weren't there? It seems to me that would see the CV joint either wearing/chafing on the inside of the hub; or by the action of the CV joint being pulled millimetrically back and forward, lead to wear on the diff end of the halfshaft? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #860325 7th Oct 2020 7:12pm
It's not the hub that floats, it's the halfshaft.
Wear at the diff end isn't usually a problem since the lubrication is good.
Post #860387 7th Oct 2020 9:31pm
