Home > Td5 > TD5 Fuel Pump Connector
PaulMc
Another one that I'm always being asked for.
The connectors in this series are made exclusively for BMW by TE Connectivity (AMP), and aren't available commercially (except to Jaguar/Land Rover and a few other manufacturers).
However - a 'zero coded' (universally keyed) version can be bought from a BMW dealer -
The BMW part number for the female connector, is - 61 13 8 367 076
BMW's zero coded connectors are 'Water Blue' to denote that they are universally keyed
Female terminals and seals have to bought separately (picture from BMW parts listing) -
2.5 - 4.0mm² cable
Female terminal = 61 13 8 352 926
Seal = 61 13 8 352 924
1.0 - 2.5mm² cable
Female terminal = 61 13 1 392 304
Seal = 61 13 1 383 791
0.5 - 1.0mm² cable
Female terminal = 61 13 1 392 302
Seal = 61 13 1 383 789
. Paul.
Post #859208 1st Oct 2020 9:24pm
grafty99
Nice one! Would make a good sticky post Martin? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #859209 1st Oct 2020 9:28pm
landyman37
Re: TD5 Fuel Pump Connector
2.5 - 4.0mm² cable
1.0 - 2.5mm² cable
0.5 - 1.0mm² cable
Hi Paul don’t suppose you have the part numbers for the matching connector do you
Thanks Phil
Post #1029852 30th Mar 2024 7:22pm
PaulMc
The male 4-way connector is BMW part number 61 13 8 367 075 (pictured), sold without terminals or seals.
Terminals and seals, are -
Male terminal, 0.5 – 1.5mm² – 61 13 1 376 191
Wire Seal, 0.5 – 1.0mm² – 61 13 1 383 789
Male terminal, 1.0 – 2.5mm² – 61 13 1 376 193
Wire Seal, 1.0 – 2.5mm² – 61 13 1 383 791
Male terminal, 2.5 – 4.0mm² – 61 13 1 376 195
Wire Seal, 4.0mm² – 61 13 8 352 924
. Paul.
Post #1029866 30th Mar 2024 10:23pm
