Home > General & Technical (L663) > Smart HDC with engine braking |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 |
Thanks Tim, that's very usefull information.
22nd Sep 2020 10:48am |
weeman Member Since: 13 Sep 2020 Location: AUS Posts: 8 |
Thats good to know.
What is the engine breaking like on the D240 Tim? I've haven't had a chance to test drive the diesel, but hoping it does have good engine breaking when manually held in gear. |
23rd Sep 2020 1:19am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Now the HDC operates much more quietly than in my previous Land Rover cars it’s hard to tell when HDC has taken over unless you disable it. I’ve only done one seriously steep down slope and not used the HDC and it was OK but nothing to match my TDi300. More practice might be required! Commandshift control (manual gear shifting) of the new Defender off-road would be much nicer if LR had seen fit to add paddle shifters to the gearbox system, it isn’t helpful to have to take a hand off the steering wheel to do a manual gear shift that in other LR models can be done with a finger on a paddle. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
23rd Sep 2020 6:53am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2688 |
Surely you just knock it into manual (“sport”) mode and then you can hold it in a specific gear in low range to use the engine braking, same as on an old Defender?
I know it’s an auto but I would presume that it would be able to lock up to achieve this. |
23rd Sep 2020 3:00pm |
Even in manual shift the computer will decide if you should have engine braking or HDC unless you disable the HDC by its on/off switch which is how I prefer to drive it, HDC when I want it not when the computer thinks it’s needed. I read somewhere recently though that with the new software in Defender that even if you switch off the HDC when using one of the TR programs it runs in the background waiting to cut in without being asked........ similar to the stability controls on the sporty Mercs, even when you switch them off they aren’t fully off and will still intervene. You don’t have to use the programs and can still drive it old Defender style with just the low ratios and centre diff and HDC turned off, which is my preferred setting! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
23rd Sep 2020 3:20pm |
