![]() | Home > Puma (Tdci) > Weird noise. |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
You will need a new fly wheel as well I expect. ££££££££
The simple fix would be to PX it to the dealer let them sort it and you drive away with a new ![]() ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
But at least the Puma flywheel should be cheaper than the awful dual-mass abomination needed on a TD5 every time the clutch is replaced! |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 ![]() ![]() ![]() |
I doubt the flywheel needs replacing as the main problem is the clutch plate springs. Only if they have let go and scorred the flywheel would it need replacing. Allan |
Yea I know I am just winding Red Dot up ![]() ![]() |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Goes in tomorrow and i have told Morrisons to do as required and charge me what they want and i will bend over provocatively when the bill is raised!!! NOT.
Getting a FL2 courtesy car so i may do the west-coast with the dogs.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
Good luck RD - at least a FL2 will be more satisfactory than an outdated Defender
![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Good luck RD
Allan |
FL2 feels so soft and it rolls like feck and it is quick but not for me... im missing my brick already. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Good for you - I knew you'd come round to the Def2 way of thinking ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Landyrob Member Since: 07 Jul 2011 Location: Switzerland Posts: 93 ![]() ![]() ![]() |
my clutch has now 64000 km still the first one, does rattle a bit when you leave it in standstill but it's still running, gears still change perfectly.
Mine seems not to release 100% and get a bit of backlash on the props and makes a wee crack when in neutral when the pedal is pressed and released...
Dealer has a Grey Metallic (not sure if it is Stornaway) Utility XS with black chequer plate and Saw-tooth alloys and 235 BFG all-terrains and it looks mighty nice... just 33 reasons why it won't be mine. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
LRCS, very helpful... dealer, not. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
All sorted now, what a difference... turbine smooth changes and smooth start ups and shut downs. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
