- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
CallumB
Oldowner wrote:My thoughts are that it would’ve been cheaper and easier for Land Rover to produce a one piece shaft than the two piece design, so there must’ve been a reason to make it two piece (although admittedly, this is Land Rover in the 2000’s we are talking about).
LRO mag a few months back had a one piece shaft with a lifetime warranty mentioned. However, I read some views on here that it would only cause wear elsewhere. I'm dithering which to go for (Ashcroft or one piece) - will probably go the tried and tested route!
23rd Oct 2020 8:29am |
