Home > Off Topic > Underfloor heating
Page 2 of 2 <12
bodstruck
My engineered wood gives off a decent heat so certainly not useless. As you say, just not as good as the others.
Just get one with as low a u value as poss and couple it with a specific ufh underlay and I am sure you will be very happy.
We have had our ufh in for years and been a very happy with it. It stays on 24/7 and has been quite economical. I had a set back timer system installed but after doing some tests it was actually more efficient to leave it set at the same temp all the time. You can get away with a lower temp as the heat emanates from.the floor. Our runs at 19 and is fine for all. We have rads upstairs on a timer.
Post #853395 31st Aug 2020 5:18pm
Grenadier
Pleasure and understood re the slab. Engineered flooring is fine. Get your builder/heating engineer to work out what they expect the HW temp to be in the pipes and then speak to your preferred wood flooring specialist to determine what tolerances their flooring has. Go engineered, check how thick the flooring is and what glue/bonding/fabrication system they use and whether the estimated temp will affect them. Make sure you know the desired depth of flooring you want so that your builder/engineer can correctly calculate the temp. Thicker the flooring, higher the temp etc.
Note that the panel systems used by Continal can be laid on a slab, with the flooring directly on top, so still offering you speedier fitting, (no curing time as no screed) and the same control as a radiator system. Just cos you have a slab doesn’t mean you have to fit the pipe work into the screed or even need a screed at all....just remember that this may impact door thresholds as you may be saving as much as 60mm if you were planing on using a floating screed and then don’t. The panels are approx 20mm thick. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #853397 31st Aug 2020 5:24pm
Grenadier
Post #853398 31st Aug 2020 5:25pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Catherham,
We in the process of fitting UFH to ur kitchen and downstairs toilet, we had the same concerns as yourself, my friend owns an UFH company and carried out the install for us, we have gone for a manifold and control system from Robot https://www.robotunderfloorheating.co.uk/underfloor. We lifted our chipboard floors and exposed the beams to accommodate 50mm PIR insulation and heating pipes with an 80mm biscuit mix screed to joist level, this was then topped off using Knauf Brio 22mm thermally transparent screed boards.
I called on one of my industry contacts to specify the correct timber flooring for our toilet as my wife wanted herringbone grey oak, they confirmed that high quality engineered timber flooring would withstand the temperatures and with the additional pipe loops installed would still radiate enough heat to keep the room warm.
Let me know if I can help with any information
John
 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #853588 1st Sep 2020 12:43pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
We built this place for one of my customers 7 years ago and got under floor on ground floor and 1st floor 25% covered in slate and 75% covered with engineered bamboo Bow down all on a biscuit screed between 2x1 battens at 400 centres Thumbs Up and it works perfect to this day Thumbs Up
Post #853597 1st Sep 2020 1:09pm
Pilgrimmick
I have UFH in a converted barn. I have exceeded the specs to provide a good base, the screed is covered with Karndean (spelling?) flooring. Looks great, easy to clean and feels lovely in winter. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #853607 1st Sep 2020 2:18pm
Page 2 of 2 <12
