Home > In Car Electronics > ARB wiring using TD5 switches
Rugratnav
Evening Guys,
Does anyone know if there is a diagram for wiring up an ARB compressor and actuator but using the Bearmach/Land Rover switches that fit in a TD5 dashboard? (Not carling type)
If there is no diagram, would anybody be able to to offer advice how to do it as we’re struggling to make it work!
Thanks
John In Yorkshire, but near enough to the Lancashire border!
Post #853008 29th Aug 2020 9:19pm
hank
Which switch blanks do you have? Or which circuit are you looking to use? > 110 XS Double Cab
Post #853018 29th Aug 2020 10:01pm
ibexman
Watching with interest
Post #853019 29th Aug 2020 10:03pm
hank
As a starting point there is some useful information here.
https://www.defender2.net/forum/topic63641.html > 110 XS Double Cab
Post #853021 29th Aug 2020 10:11pm
Rugratnav
We are using these switches;
https://bearmach.com/switch-assembly-air-c...gKCh_D_BwE
And we were trying to use the ARB loom;
https://cdn.devon4x4.com/techpdf/Product%2...0RDCKA.jpg
but unsure how to make it work together.
Thanks In Yorkshire, but near enough to the Lancashire border!
Post #853022 29th Aug 2020 10:15pm
hank
Yes but which space in the dash do you have spare currently blanked off? Behind any blank switches is unused wiring that you can make use of so need to know which circuit you intend to use. > 110 XS Double Cab
Post #853060 30th Aug 2020 8:46am
